Question about Samsung HT-X50 System
No sound out of 4 of 5 speakers when using tv only.
Surround Sound works perfectly when playing DVD. When I switch to TV, only one speaker plays. If I switch the sound modes around, I can get one side only to play (center and right side only).
  • 56 Answers
Switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Posted on Jan 26, 2009
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Samsung HT-X50 System Logo
158 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
