Question about GPS
Compass says signal disturb on my sherrill digital handheld compass
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Raymarine smartpilot x-5. The fluxgate compass is some 45 - 60 degrees out from the boat compass. I have tried to recalibrate but this does not solve the problem. Any ideas?
First of all - is the boat compass correct? How does it align with COG? Secondly, do you have a magnetic field that interfere with the fluxgate? To test for this you can use the compass on your smartphone or a handheld compass, move about in the boat and keep the phone/compass aligned with the keel. If the heading drifts in the area where you have your fluxgate today, move it.
Feb 25, 2014 | Raymarine X5 Wheel Smartpilot E12201
When is a compass in need of repair?
    • 1.
      When there are cracks in the dome.
      2. When fluid levels are low,
      creating a bubble or fluid is all together empty.
      3. The dial or card is
      discolored or yellow.
      4. When the dial begins to stick
      * follow these steps to test dial.........
      While dockside take note of the compass heading. Hold any magnetic object
      to the compass so that the original heading is deflected about 10degrees.
      Remove that object, and see if the dial returns to it's original
      heading.
      Repeat this several times deflecting the compass to both sides.
AdChoices
Jul 09, 2012 | Camping, Backpacking & Hiking
Compass 'pops up' in middle of a training run - want to stop this
You are in the mode that is used to navigate to a location. When the compass is up, hit the "quit" button, then select "stop go to" and it should stop.
Jan 25, 2010 | Garmin Forerunner 405 Handheld GPS...
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Feb 08, 2009 | 1997 Nissan Pathfinder
1997 Toyota land cruiser prado Rz compass bearing, temperature setting, etc.
I've been resetting pajero's compasses but try to get to an area where you can do 360 degrees turns (empty car parks, ) press the reset button and make 2 complete 360 turns slowly and normally this should set the compass bearing.
Let us know how you get on. Cheers.
Sep 14, 2008 | 1996 Toyota Land Cruiser
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
GPS Logo
123 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
