Question about Sewing Machines
I dont know where to set the tension because I purchased this used in a shop I have not been able to work with it now the bobbin thread gets caught on bobbin.
I have had two people look at it they are all saying its in the tention but I can not believe that because the neddle is not picking up.
  • Sewing Machines Master
  • 1,564 Answers
Could you please provide the make and model number? it's hard to answer questions without that info.
Posted on Jan 19, 2013
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
SOURCE: Bernina 801 Sport
Did you clean out the lint under the plate?
Posted on May 18, 2008
geemarie
  • 876 Answers
SOURCE: I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Posted on Aug 07, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
  • 4 Answers
SOURCE: Thread caught up around bobbin!
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
The bottom thread is real loopy. I have adjusted the top tension and it helps a bit but still to loose
Remove all the thread from your machine. Install a brand new needle. Raise the presser foot and re-thread the upper thread, making sure you are following the correct threading sequence. Confirm that the bobbin thread is threaded through the bobbincase properly. Now, perform another test stitch. Is the bobbin thread still looping?
If you have already tightened the upper thread tension and the bobbin tension is still too loose, then you may need to tighten the bobbin tension. First, mark with a permanent marker where the slash of the screw head meets the bobbin case. This will mark where the screw was originally set before you begin making adjustments and allows you to return the screw to that position should you need to.
Set the upper tension to the halfway point between the high & low number. This is what would normally be the standard.
Then gently turn the bobbin tension screw to the right 1/8th of a turn at a time. Then test. Keep adjusting until the bobbin thread tension is correct. The tensions are correct when the upper thread and the bobbin thread meet in the middle of the fabric.
Nov 15, 2015 | Sewing Machines
Replacing the bobbin case
Remove the bobbin and drop a little oil in the bobbin holder at the center which you usually insert the bobbin...
Happy Fixya... keep me posted on the result....
Feb 05, 2008 | Singer 7436 - INGENUITY
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
Top tension has to be turned all the way down to get good stitch, then thread gets caught in bobbin and lower hooping on thread..
Grab some scrap fabric of the same type you'll be sewing. Tighten your top tension and test sew until you see until you see the top thread of a seam go like a straight line and the bobbin thread loops on top of the seam. Then back off of the top tension until those loops disappear.
If you never see it the top thread go like a straight line... your top tension needs to be cleaned... and make sure you have the pressure foot UP when you thread the upper thread.
Aug 03, 2012 | Sewing Machines
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Thread winds around bobbin and gets caught
Check the way the machine is threaded.First, remove the thread completely and rethread it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Mar 19, 2009 | Kenmore 15516 Mechanical Sewing Machine
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
