G e washerwhdre526e1ww water not turning off - Washing Machines
    Sergeant:
  • 291 Answers
It's likely either a pressure switch or inlet water inlet valve malfunction. Can you give me a model number for your machine? Also a little more info on symptom. For example does it overflow when running a cycle? Or is there water in the tub when you go to use it?
Posted on Jan 19, 2013
Why won't the main water supply knob turn to allow water to the water heater
Shut off unit then turn off water to house at water main out side. Drain water heater remove old valve install new
Jul 20, 2014 | Reliance Water Heaters
Tip
Water heaters
<span><span><span><span>f your water heater suddenly seems to supply less hot water and you've made sure it isn't leaking, flush the water heater tank to be sure mineral deposits are not reducing the heater's efficiency. To do this:</span><br /></span></span><span>1) Turn off the water heater's gas valve or electrical power.</span><br /><span>2) Let the water cool.</span><br /><br /><span>3) Turn off the water inlet valve and attach a hose to the drain valve to run the water into a large bucket, or to a drain or the outdoors.</span><br /><br /><span>4) Open the drain valve at the base of the tank, and open one hot water faucet somewhere in the house to let in air. When all water has drained from the water heater, turn the cold water valve on and off until the water from the drain runs clear.</span><br /><br /><span>5) Close the drain valve, turn the water back on to fill the tank, and turn the gas valve or electricity back on (relight the pilot if applicable).</span></span>
on Apr 02, 2011 | Heating & Cooling
Stopped making ice after water had been turned off and turned back on
turn water off to ref disconnect the water supply line to ref put the supply line in a large bowl or bucket the turn the water on to see if you have water going to the ref if there is no water you may have to replace the piercing valve on the water supply line
Nov 17, 2010 | GE GTS22WCP Top Freezer Refrigerator
Want to change water faucets
Centre tap of the rinnai will turn off hot water supply only.
Easiest way is to turn off your mains water supply. This will isolate both hot and cold, no need to turn off anything else
Jul 11, 2010 | Rinnai Digital Remote Water Heater Control...
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: Unit isn't turning on when I turn on the hot water...
Has it ever run? Is cold water going to cold water inlet? Hot out to hot water piping? Power ON? Control pad on? gas pressure correct?
May 16, 2010 | Rheem Tankless Hot Water Heater...
Shut off water to house and drain water
Depending on where you live you may need to call your utilities company to come out and turn off your water. Before the water is shut off be sure to turn off your hot water heater. When the water is shut off you can drain your system by turning on an outdoor faucet which is normally the lowest fixture in the house. You will also need to turn on the hot water valve at any fixutre to drain the hot water out o the lines. Water will still remain in the hot water heater.
Mar 11, 2010 | Home
How do i flush my 50 gal. elctric water heater? whirlpool.
Turn Power off first.... Attach hose to bottom spigot, turn counter clockwise, Let pressure with water still on clear anything in front of drain. Then you can shut the water off on cold water side... Let unit drain down. Turn clockwise and close drain . Turn water back on and let fill , turn a inside faucet on to get air out of line. and then you can turn power back on
Feb 18, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Main water valve
Your house is all ran in pipes and fittings. A lot of fittings, every turn, every time it splits off. When you turn off and on the main water, there is some air that gets into the line. When you turn it on the water pushes the air out with water preasure. That makes a water hammer, a pounding of water. the work hammer should say a lot. Like anything else, all those fittings can leak. So turning the water reduces the preasure you put on the 100's of fittings you have in your house. Why take the chance, turn it on slowly.
Don't mind the title it made me choose one. Main water supply valve was not one of them
Sep 09, 2009 | Computers & Internet
Water pressure
There is no control to turn the pressure up.
Start by checking the water supply to the Ref.
1. Turn the water supply off and disconnect the water line at the back of the ref.
2. Turn the water back on and fill a small pan with water to observe the pressure. low pressure here then replace the tap valve on the cold water line. If the pressure is ok then the problem is in the ref water valve.
Dec 16, 2008 | Frigidaire FRS26R4A Side by Side...
I want to take a sink unit out. This means I have to turn off the cold water mains and hot water. I have a Worcester combi boiler and am not sure how to turn off the direct hot water . Can you help
Under the sink itself there should be shut-offs. To turn off the water to your boiler, first turn the power off to it at the breaker box. Then on the boiler itself, there will be some valves. One of the valves will be located in the copper line that comes from your water meter. Turn that one off. If you want to turn off the water to the whole house, right next to the water meter there should be a valve. Turn it off and open all faucets to ensure the water is off. Reverse this procedure when establishing water pressure again.
Jul 27, 2008 | Heating & Cooling
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
