Question about Dodge 2007 Grand Caravan
Van won't start, just beeps
Originally thought the battery was dead. Jumped it. Did not help. There is power to the dash and interior lights. The keylees entry is not working. I searched the internet and called the dealership. All the info on the net points to the Sentry Key Immobilizer Module. I was told there is a way to bypass it??? The dealership said it could be the SKIM or the WCM. Apparently I have to get a PIN code from the dealership in order to replace the module? I pulled the IOD fuse, sat in the vehicle, doors closed, turned the key to on off position to get a code. The only code was P0073 for the Ambient air temp sensor. And I replaced the battery in my kefob. That would not have anything to do with it right? So what I really want to know is if there is a way for me to bypass and save me money on a tow, shop fees, part costs (I'm told by the dealership it could be anywhere from $150 to $500)
  • 422 Answers
SOURCE: 1998 dodge caravan,sport----3.3 (61,000) miles
the computer does not lose programs after power lose. check the ground cables or the asd relay. and get a new mechanic
Posted on Aug 25, 2008
  • 5568 Answers
SOURCE: IR control module for remote entry is inop
What I find confusing is the designation 'IR' which is applicable to TV and stereo remotes but have never heard of it used for automotive locks. It stands for 'Infra-Red' and this is only effective with 'line of sight' applications.
I know every one I've ever owned could be operated without the vehicle even visible as long as the range was not more than 50-70 feet.
These systems use radio frequency signals modulated by digitally coded signals to prevent 'one remote fits all.'
It would be interesting (as long as your patience doesn't wear thin) to find out how you have resolved this.
Mr. Massengill gave good advice since the battery contacts are now made so cheap that they won't donate a few microns of gold to them. Most I've seen were tinned at best.
Posted on Dec 15, 2008
  • 85 Answers
SOURCE: 2000 G. Caravan battery discharges & will not start
you may very well be on the right track here... if it were me and my van here, i would replace the dimmer. i bet you can get another from a parts house without going to the dealer. then again... get the price from the parts house and see if the dealer will match the price for the part ( under the current big 3 situation they may do it)
Posted on Jun 17, 2009
  • 412 Answers
SOURCE: Power door lock do not work. So far I have
2005 caravan's had software issue with power door lock operation..the body controller may need a software update..check with local dodge dealer to see if service bulletin applies to your vehicle..have seen body controller problems as well
Posted on Jun 20, 2009
  • 6674 Answers
SOURCE: We have a Dodge Caliber and when we went to start
Check with dealer on technical service bulletin, and/or recall regarding this. My Daughter had same problem, it was to do with sensor in ignition for recognizing key.
Have heard some say, reducing static before putting key in also helps, such as rubbing hand across metal roof or door post prior to inserting key. Dealer stated it's to do with radio frequencies interrupting signal, but they don't sound 100% sure on that either , but apparently new part is less, or not as sensitive.
Posted on Dec 20, 2009
Starting problem (see details), on 1998 Town & Country.
Check your battery cables and starter cables especially the connectors and bolts under the hood. The bolts and connections could be loose or corroded. Check the connections near the battery and on the battery since many times mechanics mess with these the most. My guess is something is loose if it starts well most times, but fails occasionally. Did you look for blinky codes or DTCs? A '47' (or P0562) could mean a bad battery or alternator, and a '12' (or P1684) could indicate intermittent connections. Do the dome lights dim or stay well lit when the clicking is heard during cranking? If so, then the issue is most likely near the battery and if not then the issue is more likely near the starter. Good luck. There are a lot of wires under the hood.
Oct 10, 2017 | Chrysler Cars & Trucks
Kangoo van 17dci laying for 8 weeks and now wont start
when you say won go do you mean that there is no power at all,( flat battery,) there is power only lights in the dash? First of all check whether you do have powerful Battery for a crank start. If not then ask for a help from a qualified electrician to jump start it by means of a strong battery and leads. 8 weeks it is a long time for a battery to drop power down possible completely dead if the battery is old.
May 28, 2013 | Cars & Trucks
Wiring diagram chevy van
Fixed Problem (it was my van) no power to ignition wire at starter. Replaced Ignition lock cylinder. just worn down. (Delivery van 50-60 starts a day). 160k miles.
Apr 25, 2013 | 2000 Chevrolet Express Cargo
Focus 1.8 tdci 2009 won't start dash lights go crazy noise from fuse box
check your battery cables for corrosion clean them and start the engine
Mar 25, 2013 | Cars & Trucks
2006 chrysler sebring wont start
if the starter relay is clicking that means the starter is bad .
Jan 26, 2013 | 2006 Chrysler Sebring 2.7
1992 saturn sl engine won't turn over
Best case scenario: Your battery is dead or almost dead.Worst case: The engine has seized and you have to replace it. Do the dash and interior lights stay on or turn out when you try to start the car?
Apr 19, 2012 | 1992 Saturn SL
1994 geo tracker won't start
first have the battery load tested as it indicates that there is a dead cell
If there is a dead cell then the dead battery will consume most of the power from the jumper so there may not be enough left for the starter and the ignition
to check for a power drain , install an amp meter i the battery to ground wire and see what current draw is occurring when everything is turned off
up to 1/2 amp indicates that the ECM is using power for the memory
up to 2 amps indicate a light on--glove box, boot , interior radio etc
more indicates a problem relay
Oct 17, 2017 | 1994 Geo Tracker
Peugeot boxer van 2007 changed interior light bulb blew fuse, renewed fuse, lights worked, but emissions lights on dash board came on and won't go out. Help
Try reading the OBDII with a code reader and see what it is then erase codes and see if it stays off ,could be more than one circuit on this fuse so the fuse blowing has thrown the light on for whatever reason ,Also try disconnecting the battery just out of interest for a few minutes and reconnect it might go out if your lucky
Feb 27, 2012 | Cars & Trucks
Dodge 2007 Grand Caravan Logo
42 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
Richard Warren
Richard Warren
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
