Question about Sharp EL-1192G Calculator
How to put paper in an sharp EL-1192G calcuator
5 Suggested Answers
  • 168 Answers
SOURCE: where do i put the paper into to replace a new roll
There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
Posted on Feb 04, 2008
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
RobertFonner
  • 67 Answers
SOURCE: How do you replace the ink on a Sharp EL-1192G
This diagram should help you with replacing the ink roller.
Posted on Sep 04, 2009
  • 23 Answers
SOURCE: I need to install new roller ink for the Sharp EL
You can get a new ink roller at http://www.calculatorsource.com/s-ea781rrd.html
Posted on Mar 26, 2010
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
    Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
    Mar 08, 2010 | Sharp EL-2630P Calculator
    I need to install new roller ink for the Sharp EL 1192G, doesn't seem like the red is working correctly.
    M=500 and S=100 in a normal distribution, what percentage of the subjects have scores between 400 and 600
    Mar 01, 2010 | Sharp EL-1192BL Calculator
    How do you replace the ink on a Sharp EL-1192G calculator?
    Sep 03, 2009 | Sharp EL-1192G Calculator
    I'm trying to load paper into a Sharp el-1701c that I inherited.
    My wife solved it by finding a thin little slot on the back of it where you put the paper in. Worked
    beautifully. Thanks any way.
    Dec 19, 2008 | Sharp EL-1701C Calculator
    Decimal point
    You need to put your tab where it says K*A and set that to A (it is the 3rd set of buttons) and then you need to go to the 5th set of buttons that show F 6 3 2 1 0 and set this to 2. Hope that works :o)
    Oct 02, 2008 | Sharp EL-2196BL Calculator
    Where do i put the paper into to replace a new roll
    Feb 04, 2008 | Sharp EL-1701C Calculator
    Sharp EL-1192G Calculator Logo
    104 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
