Question about Lionel A Christmas Story Gauge Train Set Nip
Lionel battery operated g scale locomotive will not move
Bell and whistle work but loco shuts off if dial is turned forward or back
  • Anonymous Mar 20, 2014
    rear part of frame broken off.
  • 161 Answers
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Posted on Mar 02, 2013
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: my lionel train won't run at all. What do I do?
Did you ever solve your problem? My son is having the same problem.
Posted on Dec 05, 2010
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
  • 34 Answers
SOURCE: My cw-80 Lionel transformer has
The CW-80 is not suited for electronic sound systems. The output is non-sinusoidal. When electronic sounds are generated for some locos, the sound will be garbled. Use another power source. The Z1000 MTH power source or similar is recommended as are many other older Lionel standard power xfmrs. For the sound stay on problem with switch off, try putting a fixed load on the tracks ie: An accessory of some kind (lights etc). Usually a fixed electrical load will fix this problem. Overall, I would recommend changing out the power source and save yourself a lot of headache..
Posted on Sep 05, 2011
jssummerfiel
SOURCE: I have a problem with
Had trouble with 072 switchs. Something is causing half the switch to loose track power. Most of the time it is the wide place on the switch. Had two of mind on both ends of the hot rail hookup do the same thing. What I did was have hot rail hookup in five or six different places. No problem now. Also have problems with derails at switch when going through ir backwards. Lional should in stall a small spring at the switch point to help hold it against the rail. No recommended but I took a punch and flatten the rail so it would push more on the switch point. OK so far. Hard to remove switchs when all your Fastrack is screw down.
Posted on Dec 17, 2012
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Lionel train problems
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Dec 24, 2013 | Crafts & Hobbies
Check to be sure that the reverse unit is on. This may be a lever on the top of the locomotive or a slide switch under the engine. If that doesn't solve the problem, you will need to take the engine to a service center to be repaired. A list of service centers can be found at Lionel.com
Dec 20, 2013 | Crafts & Hobbies
Have a lionel holiday tradition express. Lights are on, but train won't sing or go forward. Changed batteries and nothing.
Nov 12, 2013 | Crafts & Hobbies
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My cw-80 Lionel transformer has button issues when operating both traditional and tmcc loco. the horn and bell sounds are goofy. and on some of my traditionaltenders the sounds are still on when the...
May 14, 2011 | Lionel Cw 80 Transformer
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
Lionel A Christmas Story Gauge Train Set Nip Logo
254 people viewed this question
Top Lionel Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
