Question about Sony Audio Players & Recorders
BDV-E870 i have sound when useing DVD but not when useing satilite.All cables are correct.It worked one day then there was nothing the next day
  • Sony Master
  • 3,904 Answers
Make sure the auido input selection did not get changed on the theater system. Audio and video need to be matched .
Posted on Jan 20, 2013
2 Suggested Answers
  • 18 Answers
SOURCE: Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia
Three things can cause this:
1) not all HD is recorded in surround sound. You can very well watch an HD program that just has Left/Right stereo audio. Tombstone on bluray is even only in Dolby 2.0
2) wrong connection is used. If you only use red/white analog stereo cables you will only get sound out of the left/right mains.
3) setting on the cable box is set to stereo and not surround. Changing this varies by cable box manufacturer.
Posted on Mar 01, 2011
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
My sanyo tv picture wont come on except when you first turn it on then it goes off, the sound works
Have you tried using a different input like a DVD or Blu-ray player with a HDMI cable? If you get the same issue using a different device and a different input then it is possible the Input board in the TV is fried, lucky all the boards in LCD/LED TV's are real easy to replace and individually are fairly cheap.
Jan 02, 2015 | Sanyo Televison & Video
Bdv e3100 region free
try this
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Oct 16, 2013 | Sony BDV-E3100 5.1 Channel 3D Blu-ray Disc...
No picture but have sound
no video output seems the video output part is faulty ask for tech to have a look
Jul 11, 2013 | RCA P61939 61" Rear Projection Television
Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia TV and cable box. No sound comes from rear or center speakers with HD cable.
Mar 01, 2011 | Sony BDVE300 Theater System
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I have same problem at first just had sound but no pic now only have sound for a minute when it turns on then nothing my tv was working fine shut it off one night turned on next day and the problem was...
Check and see if you have the sound settings to Stereo, and Audio to Main, not SAP.
Try the TV with a DVD player, does that work?
Are you using a cable TV box? Try the TV connected directly to cablevision. If that works, get a new cable box.
The TV may need a repair technician if the above tests don't work. Audio is generally not user serviceable without a lot of electronics skill, due to parts size and circuit complexity.
Mar 22, 2010 | Sony KV-36XBR250 TV
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Tv sound on home theater kit
Hi Every one.
Had same problem with my HDMI connection on my sony bravia and sony theatre system, resolved by conecting a scart lead from the theatre system to one of the free scart sockets on the back of the TV, leave your HDMI connection in place as the DVD signal comes from this,
hope this helps!
Dec 20, 2007 | Audio Players & Recorders
Was watching TV and now Black with White Lines
I call a tech in. It could be quite a few issues.
May 14, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
