Question about Vacuums
UGH! We cleaned this thing in and out even took it apart and cleaned the gears with Q tips. It's SO LOUD lol what in the world is that noise?!
    Genius:
  • Vacuums Master
  • 1,669 Answers
Maybe the gears need lubrication like WD 40 o9r CRC spraw?
Posted on Jan 19, 2013
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
My brush stopped spinning, but instead makes a loud plastic grinding noise.
Both ends of the brush roll should spin freely. You need to replace the brush roll.
Jan 21, 2014 | Hoover SH40060: Multi-Cyclonic Canister
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson is making a really strange loud sound. It appears to be working. I just took it apart and cleaned the filter and the wand. When I put everything back together, it started making a heavy whirring...
Check the tips of the beater bar. I "bumped" mine to hard and broke a tip. Still worked! Just noisy. Called Dyson support and they sent me a new one no charge. Note. Mine had a loud whirring and a vibration.
Jan 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Roomba vacuum only goes around in circles then stops and blinks 9 times.
clean your filter . mine was doing the same thing and i took everythng apart under it and low and behold it works wonderful now. but now ive lost the lil brass screw that holds the lil brush on ugh
Dec 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Bissell Proheat 2x. The pump wont prime. The water is full and the tanks are sealed. Second time we hace used it.
I had the same problem. I took the whole thing apart and cleaned all the lines, water heater, brushes, etc. After putting it together the tools sprayed great and the side sprayers but the water tank would not allow the water out. THEN I saw this. http://www.bissell.com/FAQDetail.aspx?id=1122 and I was finally able to figure it out. So what I found out was that the water tank gasket was damage. lol
Dec 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Dec 15, 2008 | Roomba Robotic Floor Bagless Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
