Question about Bose Lifestyle 25 System
Bose Lifestyle 25 - no display indicator lights
Our Bose Lifestyle 25 system has been working fine. Just got a new Comcast cable box (the old one wasn't bad, just old and big - newer, smaller upgrade available). Changed out the cable box and everything (cable, TV, DVD/VCR) is working fine, but suddenly there are no indicator lights on the Bose unit. I am skeptical the lights coincidentally burned out. This was a simple changeout of the cable box - no rerouting of cables, no changes to the equipment, etc. The Bose system itself is working fine as usual. Any help you can provide is much appreciated!
  • 1 more comment
  • chris0424 Feb 22, 2009
    Similar problem, I noted the display was less bright. Then the other day off altogether. Unit functions fine but no display is visible.
  • danielpaul20 Mar 13, 2009
    Same problem...very low to no display lights at all. And when I power my system off it will no readily come back on again.
  • tbag811 Mar 18, 2009
    Same here.
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
  • 10 Answers
SOURCE: system does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Posted on Aug 20, 2009
Bose lifestyle 48 power went now not switching on..
Bose Lifestyle Problem - ecoustics.com
www.ecoustics.com > ... > Home Theater in a Box Forum
May 27, 2006 - My Bose lifestyle 38 will not switch-off completely and the "Saving your music ... On the phone they said power down and check cables and ... Here we goagain with more Lifestyle 38 problems . We are now unable to watch DVDs or listen to CDs without ... Recently bought a TV and Lifestyle 48 system. Archive through April 10, 2009 - How to DIY Repair a Bose ...
Jan 19, 2009
Archive through January 06, 2008 - How to DIY Repair a Bose ...
Dec 26, 2006
How to open the bose lifestyle 25 receiver
Aug 14, 2005
Archive through December 25, 2006 - How to DIY Repair a Bose ...
Mar 7, 2005
More results from www.ecoustics.com
Oct 24, 2015 | Bose Audio Players & Recorders
Bose lifestyle plays for 5min shuts down
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Jan 13, 2013 | Bose Lifestyle 8 series II System
How do I setup and new samsung led with a 12 year old bose lifestyle 25 series II?
... According to their manuals. The TV is new so it should cover that end. Bose.com covers the other.
May 14, 2011 | Bose Lifestyle 25 System
I have a Bose lifestyle 25 from 1997 and I need a receiver power cord and a complete harness between the subwoofer and tha acustimass boxes. Do you know where I can find it ? Thank's
There's nothing special about the original power cord, so I'd go to Radio Shack or any electrical supply store and get it for $8.
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
eBay has several of the unique connections you want.
Search "Bose lifestyle 25 cable".
Apr 10, 2011 | Bose Lifestyle 25 System
I have a Bose Lifestyle 25 series II system and the display is dark and will not light up. Are ther bulbs in there that might be burned out or what do I need to do to fix this problem so the display...
Had the same problem. The electrolytic capacitors on the power board were not well - I tested a few of them and ESR values were all high. One of my 100uF caps was open circuit and not charging. I replaced all caps on the power board and display is fine again. Hope this helps.
Feb 05, 2011 | Bose Lifestyle 25 System
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 25 System Logo
178 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
