Question about 2wire 1800HG Router (RG1800HG00)
Need a copy of instructions
I've lost my instructions on how to set up my zwire 1800Hg wireless router. Can you help?
  • Jlang Dec 19, 2007
    Lost instructions for installing 1800HG
    President:
  • 2,961 Answers
You can download the manual here, it's the bottom one, the '1000 series' http://www.2wire.com/index.php?p=266
Posted on Jul 15, 2007
SOURCE:
How do I enable wireless on a 2wire 1800HG router?
Hook to any port by copper line and then from a browser access 192.168.1.1. If you received this WAP from Bellsouth/AT&T etc. you may need to get the admin password and user from them. There you will have a section for your wireless settings that is very similar to Linksys, Dlink, or any other wireless DSL router.
Mar 02, 2010 | 2wire 1800HG Router (RG1800HG00)
I need to block my neighbors laptop he has my wep code how do i do it
You will need to change the wireless security code on your router.
If your neighbor has the wep code then you can change the code on your router.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Jan 25, 2010 | 2wire HomePortal 1800HG Router...
Can you tell me how to set up wireless connection?
You can find a detailed walkthrough of setting up wireless connections on your 2wire here.
If this helped you then please help me and vote kindly, thank you
Oct 15, 2009 | 2wire HomePortal 1800HG Router...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Connecting laptop to 2 wire
Here is a link with downloads for the User guide and Wireless Configuration guide for your 2-wire:
http://www.dsldepot.com/dslmodem.asp?modem=238
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 10, 2009 | 2wire 1800HG Router (RG1800HG00)
Samsung bd-p1600 wireless connection to 2wire 1800HG router
Check CNET Samsung forum. There are several posts with the same problem. A couple solutions and basic confirmation that Samsungs newest fireware is bad. I wish their support helpdesk would realize that instead of telling me to contact my router support.
Apr 24, 2009 | 2wire 1800HG Router (RG1800HG00)
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
Aug 30, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Can a 1800HG gateway in my garage/workshop link *wirelessly* to my 2wire 2700 HG-B wifi AP internet in the house?
try going onto http://192.168.1.254/xslt?PAGE=J30&THISPAGE=J29&NEXTPAGE=J30 on the computer connected to the 1800hg and set the router onto bridge mode (deselect enable routing). You might be able to set the two routers to connect then from here: http://192.168.1.254/xslt?PAGE=J09&THISPAGE=J30&NEXTPAGE=J09 or somewhere else in the MDC, not sure if it will work as I haven't tried it, but I hope it helps.
Feb 19, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire 1800HG Router (RG1800HG00) Logo
450 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
