Question about Apple iMac G5 Desktop
Four bongs at startup
Why are there four bongs at startup? What does it mean? Reset pram did not stop it.
  • 48 Answers
I believe you are supposed to hear four bongs when you reset PRAM.
Posted on Dec 07, 2013
Hpw to reset macbook pro
  1. Turn off your Mac (if it isn't already off).
  2. Hold down these four keys right after you press the power button: command+option+P+R (that will reset the PRAM).
  3. Keep holding down those four buttons until your Mac restarts and you hear the second startup chime.
May 28, 2014 | Computers & Internet
Slow macbook
reset pram.
Install os system disk and boot from optical drive by holding down letter C.
go to disk utilities and go through all four options.
Mar 23, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My iMac G5 computer starts up and then gets to the apple logo ,it ses like it loading up but nothing is happening.
The PRAM is the first thing to try and then there might be an internal reset button next tot he installed RAM. Seen it in older eMac and iMac desktops but not sure about yours.
Resetting the Parameter RAM
One easy fix for many issues is to simply reset the PRAM to its default state. This will cause some data to be lost, specifically the date, the time, and the startup volume selection. Luckily, you can easily correct these settings using your Mac's System Preferences.
  1. Shut down your Mac.
  2. Turn your Mac back on.
  3. Immediately press and hold the following keys: command+option+P+R. That's four keys: the command key, the option key, the letter P, and the letter R. You must press and hold these four keys before you see the gray screen during the startup process.
  4. Continue to hold down the four keys. This is a long process, during which your Mac will restart on its own.
  5. Finally, when you hear the second startup chime, you can release the keys.
  6. Your Mac will finish the startup process.
Jun 06, 2012 | Apple Computers & Internet
What does it mean error 5b00, and how do i resolve it
You will have to do a reset. Follow the instructions below
1. power off.
2. hold stop/reset, hold ON/OFF
3. release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4. wait untill LCD display shows “Canon Idle”,then push stop/reset four times, quickly
5. then push power twice, quickly
6. power off and power on
Jul 14, 2010 | Canon PIXMA MP130 All-In-One InkJet...
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
My iMac G4 turns on and goes to the grey startup screen with the apple and loading circle, but stays there, and gets stuck, and after a few minutes shuts off on it's own.
You may have to reinstall you OS e.g. tiger, leopard with the disks that came with your computer. that should solve your problem
Jul 18, 2009 | Apple iMac G4 Desktop
: My macbook stopped recognizing both my DVD and CD drives, help
try to reset the PRAM (Apple - alt -P - R) , and hit the alt key at startup to see if you can startup on a volume
Jan 31, 2009 | Apple MacBook Pro Laptop Computer with...
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 | Baby Gear
Four Beeps on startup on a Panasonic uj-810b
sounds like it's trying to boot to the dead drive- pay attention to the screen when you power on F12 or F1 whatever get's you to boot menu- change the order to exclude the broken drive- it should stop beeping.
Jan 14, 2008 | Panasonic (UJ-825-B) DVD±RW Burner
Apple iMac G5 Desktop Logo
67 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
