Question about Minolta magicolor 2400W Laser Printer
Magicolor 2400w won't feed paper
The printer starts up and acts like it wants to print but stops and won't feed the paper even though there is paper in the tray
  • Anonymous Mar 23, 2014
    everytime the paper feeds it jams
  • 15,935 Answers
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Posted on Jan 26, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, your described problem indicates a possible mechanical issue. In most printers, there would be a rubber wheel (or half a wheel in some) that grabs the end of the paper to provide the initial push through the paper path/rollers. If the unit has been in use for some time, it may be then wear & tear, the rubber has considerably worn out that it no longer provides sufficient grip. Alternately, it may be that this grab/rubber wheel just needs a bit of cleaning.
Pls post back results of cleaning. Good luck and thank you for using FixYa.
Wiped the roller, didn't look dirty?
Put in less paper, seems OK now?
Doing two sided, 50 sheets plain paper.
I was feeding the paper before for onesey-twoseys,
kind of lift & push a little, not tooo hard.
Posted on Feb 04, 2012
  • 4,806 Answers
Try reinstalling the printers software, after that print a test page, if it grabs the paper and prints you know it was a communication error
Best regards
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w top margin off
I spent a while troubleshooting a similar issue on my 2400W. It turned out to be the SL2 registration solenoid, which failed to engage properly. The purpose of SL2 is to stop the page temporarily until it lines up with the image on the transfer belt. Unfortunately, SL2 is very finicky, the foam pad that stops the lever flattened too much and got sticky, so the lever wouldn't engage anymore, and the paper went straight through instead of pausing briefly when using B&W mode driver, resulting in the shifted image. In color mode, I got no image, just a "paper jam at transfer roller" error message, even though the paper came out empty without jamming. I had to adjust SL2 a few times to get it to work optimally, i.e. with minimal travel and maximal holding force. Then everything worked well again.
Jul 28, 2012 | Minolta magicolor 2400W Laser Printer
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
I have only 2 problems. I have a magicolor 2400W that is about 6 or 7 years old and I bought a non-OEM black cartridge to replace the old one and I get over print in the background. If I get a OEM...
I have a Magic color 2400W, I have the same problems.
You need replace the cartrigde, after drum laser, maybe the Fuser units is failure or Transfer unit
Is more cheap if you buy a NEW one. I recommend buy the Newest model, included cartrigde , warranty and more. Replace parts on your used printer is more cost that buy a new one.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 23, 2011 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Paper feed issue
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Paper jamming, not feeding through evenly with rubber rollers
clean the rollers with propanol whcih is available small bottles with hardware vendors or with chemists. clean the rollers carefully with that try a print. if it not works then consult your service centre.
Apr 06, 2007 | Konica Minolta magicolor 2400 Laser...
Minolta magicolor 2400W Laser Printer Logo
1,131 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
