Question about Apple iPod touch 4th Generation MP3 Player
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Screen is unresponseive.
  • Apple Master
  • 27,725 Answers
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Posted on Jan 20, 2013
SOURCE:
  • 43 Answers
SOURCE: My ipod touch 4th generation
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Posted on Jan 13, 2011
SOURCE: 8GB iPod Touch Disabled
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
Posted on Jul 15, 2008
  • 59 Answers
SOURCE: itunes locks up when i connect my ipod touch
try to install itunes again
Posted on May 15, 2009
ipodslinger
  • 688 Answers
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Posted on Jun 01, 2009
dalegough
  • 12 Answers
SOURCE: Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Posted on Aug 13, 2009
Unlock a disabled ipod
Hold power button and home button at the same time untill the screen goes black or shows to connect to Itunes. Restore it from there
Feb 16, 2015 | Apple iPod touch 4th Generation MP3 Player
How to fix a disabled ipod 4th generation touch
Put the ipod into recovery mode and connect to itunes. itunes will offer to reset the device to factory install (current iOS will be downloaded and installed). This will wipe all contents on the ipod, but you can restore all purchases from Apple store.
If you happen to have a backup you can restore from that unless that backup is too new and contains the forgotten password.
recovery mode: If you can't update or restore your iPhone iPad or iPod touch
May 29, 2014 | Apple Ipod Touch 4th Generation
How to unable your ipod tuch when it says conect to itunes
explain more in def. is the problem that the iPod is saying connect to iTunes because its disabled? if so then just connect to iTunes and sync. once that is doing that go to iPod and put in passcode and it should unlock. if that doesnt work, then a restore will always help
Sep 26, 2013 | Apple Ipod Touch 4th Generation
My ipod is disabled and i need a simple way to fix it!! It says that connect to itunes
iPod Is Disabled After a series of more failed attempts, your iPod displays the same "iPod is Disabled" message, but with an added "Connect to iTunes" message. At this point, your iPod shuts down completely and you cannot make any more attempts to enter the passcode. In order to restore the device at this stage, you need to connect it to a computer with iTunes installed. Ideally, connect it to a computer that you've used before for syncing your iPod.
Sep 03, 2012 | Apple Ipod Touch 32gb 4th Generation -...
My ipod touch [4th generation] screen is stuck on the usb cord pointing toward the itunes logo
ipod touch 4 gen
Aug 19, 2012 | Apple iPod touch 4th Generation MP3 Player
4th generation ipod touch is unresponsive
Hello Jak,
Start by plugging your iPod into your computer and check if there are any updates through iTunes.
Mac products are notorious for bugging out when there is a software update and the device is not updated.
Also, plugging the iPod into itunes also helps resolve most software related issues
Thanks,
Pat
Apr 01, 2012 | Apple iPod touch 4th Generation MP3 Player
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
Jan 13, 2011 | Apple iPod touch
Open Questions:
See all Apple iPod touch 4th Generation MP3 Player Questions
Apple iPod touch 4th Generation MP3 Player Logo
140 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
