Question about Linksys Wireless-B Broadband Router Retail (DSLSBEFW11S4)
Can't get more than one pc to connect with linksys router
A few months ago I reset my router by hitting the button on the back of the wireless b router. Ever since then I can only connect 1 of my home pc's at a time.
Addtionally the router is no longer connected all the time and each time I boot up I have to connect.
I can't figuer out what profile setting is preventing multiple pc connections nor the always connected profile. '
Any advice?
  • mikeah Jan 28, 2009
    Thanks for the feedback. I can only agree that resetting the router wasn't the way to go for connectivity issues. That was what I was trying to resolve with a lap top.
    I've gone through the setup process again with the router and hoped to be back to square one but that doesn't seem to be the case now.
    Each pc is hard wired to the router and connects with it's own network connection. I still don't understand why multiple pcs can't connect now though?
    Still stumped!
  • John Hong
    John Hong May 11, 2010
    This really sounds like a cable is connected to the wrong port. When you reset the router did you move any cables? Make sure the cable coming from the modem is going to the WAN or Internet port on the router.
    Problem Solver:
  • 5 Answers
Well I'm not sure if that's correct. When you Reset your Router, you cleared all of the available Networks. Let me explain. A Router is essentially a way for one computer to get its' feed from the Main computer. So when you setup your router, you had to establish which was going to be the Main System. Generally the main computer is connected via Ethernet Cat5 cable but not necessary.
In order for a computer to talk to your Network individually it must have it's own Keycode. You Open up View Available Networks and you should be able to see all Routers within your area. You'll place the keycode in that field and then that Computer is then able to access the Internet via the Router.
Since you Reset it, you wiped out the information and will need to start over. Question : Why did you Reset it anyway? What caused you to feel the need to do that because that's never a solution for not being able to connect.
Posted on Jan 26, 2009
I can't connect to the default ip address 192.168.1.1 or even 192.168.1.10 of my Linksys Wireless-G Broadband Router Model: WRT54GS using the web browser for me to access set up? what will i do? please...
Hello
Reset the router.
1 power down pc and unplug all cables from router including power.
2 Find small reset button inback of router,use a pen tip or paperclip to hold in this button for 30 seconds.
3 Plug power cable back into router.
4 When light is on plug other cables back in.
5 Restart pc.
This should allow you to use 192.168.1.1
Also you can go to start then run in windows and type cmd then hit enter
Once box pops up type in ipconfig then hit enter.
This will show you a list of numbers,look for the one that says ip address,use it to log onto router.
Sep 23, 2011 | Linksys Wireless-G Broadband Router
Tip
Wireless Network Reset and Setup - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Next
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_field_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
  • Click on Wireless Security
  • Find the Security Mode field
  • Choose WPA2 - Personal
  • WPA Algorithm choose AES
  • WPA Shared Key type in your new password you will use to connect to your network
Click Save Changes and your router will now reboot. You will now need to enter in that same password (WPA Shared Key) when you first connect with your laptop to your wireless network
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Tip
Wireless Network Password - Linksys
Reset your router:
First
Second
almost done....
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Magoo
PC purchased last year had Norton installed. A few days ago Norton expired and ever since my wireless router no longer sends WiFi signals, WLAN light is out. How can I turn this feature back on? I've...
1.Router got a reset button in the bottom.Reset your router.Hope it will wok for you.
or
2.UNINSTALL THE WIFI ROUTER AND INSTALL IT.
3.CHECK YOUR POWER CORD TO ROUTER.
Feb 01, 2011 | Linksys Wireless-G WRT54G Router
Could you tell me what is the default password for linksys wireless-G? I bought this 6 months ago...
You did not mention which router model you are using (WRT, WAP, etc.), but my first try would be for username/password:admin/admin.
You can also go to this page and find your router in their database.
Note: The default values only work if the router is reset to factory default! If someone had changed the password already, this won't work. To reset the router to factory default, press the small reset button on the back of the router with a pen or needle for about 10 seconds while the router is connected to power.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 09, 2010 | Linksys Wireless-G Broadband Router
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
Connection problem
You can try to hard reset the router and update the firmware. Follow the steps below.
1. Download the latest firmware of the router from Linksys website. Save it on your computer.
2. Hard reset the router. Press the reset button at the back of the router for about 30 seconds, unplug the power for 20 seconds then plug it back in.
3. Connect your PC to port 1 of the router and access the router's setup page http://192.168.1.1 no username and admin for the password
4. Go to Administration tab > Firmware Upgrade sub tab.
5. Click Browse button and browse for the firmware file that you have downloaded from Linksys site. (.bin file extension)
After the upgrade, do a hard reset again. Repeat Step 2. Then you can reconfigure the wireless settings again.
Hope that helps.
Jan 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Having a big problem with my wireless router
Easy fix here.
  1. Turn your modem off
  2. Look for the reset button on the router (If memory serves, its on the back I think)
  3. Hold the reset button in for 30 seconds or more
  4. This will reboot the modem, wiping out any previous settings, including passwords
  5. Turn your modem back on and access the web based user interface
  6. If prompted for username password try the default passwords
  7. User: admin Password: admin OR
  8. User: (LEAVE BLANK) Password: admin
Voila :0) x
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-B Broadband Router Retail (DSLSBEFW11S4) Logo
715 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
