Firstly it started for a little while then kept turning on and off. Without the battery it won't turn on but shows red light. It's an e-systems laptop.
    New Friend:
    Problem Solver:
  • 8 Answers
Try removing battery from laptop then with battery out connect laptop to the mains using the power lead only without battery and see if laptop will boot up. Sounds like battery is needing replaced.
Posted on Jan 20, 2013
  • craig mavin Jan 22, 2013
    I have done this and all I get is a red light no boot up
Pyrhyc
  • 2028 Answers
SOURCE: Dell E1505 not turning On
That's a good posibility. Here's a link for Dell diagnostic codes and the manual for your machine.
http://pompone.cs.ucsb.edu/admin/530_Workstation/2codes.htm#1170334
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=e1505+diagnostic+light+codes&cat=sup
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
Posted on Jun 30, 2008
Pyrhyc
  • 2028 Answers
SOURCE: laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Posted on Feb 24, 2009
  • 105 Answers
SOURCE: Samsung R40 laptop does not turn on.
You have a failing PMU on the motherboard it is like a sister bourd allowing the system to function nomatter what the situation this is fatal if not resolved i recommend a service center
Posted on Oct 20, 2009
Testimonial: "Thank you for this."
seanpwright
  • 2030 Answers
SOURCE: laptop wont turn on, lights flashing, fans running
Sounds like your power circuit on the motherbard is cooked...really cheapr to buy a new one than to have that one repaired.
Posted on Mar 31, 2010
Testimonial: "thanks"
After charging phone,, it will not turn on...a little RED light is flashing..green normally
Hi Anonymous, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that might help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 29, 2016 | Cell Phones
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
Dec 15, 2012 | APC Smart-UPS 3000VA USB & Serial...
I can't start my 1995 hyundai elantra after forgetting to turn off the lights when going for class. I try to jump start it but the car won't start and all the lights keep on flashing and flick
After connecting battery, try using key in drivers door to lock, and /or unlock. Try passenger if that doesn't work, as well as valet key if it came with one.
Nov 21, 2012 | 1995 Hyundai Elantra
At&t fusion won't turn all the way on
at&t fusion1 firstly it stuck on the at&t logo then i did the hard reset so it start showing pink screen or some time it showing blinking at&t logo.can u find me a solution
Apr 06, 2012 | AT&T Cell Phones
2005 polaris sportsman ho my battery kept on going
start atv up and check that it is charging the battery at the battery around 13.5v roughly, then when off check battery is not losing voltage with every thing turned off ( can buy cheap little multi-meters).
Sep 21, 2010 | Polaris ATV
Won't start at all
It can be anything from a faulty power jack, to a fried motherboard. Take it back to best buy as soon as you can, and let them take a look. Nothing more you can really do.
Jun 16, 2009 | HP Pavilion tx1000z Notebook
94 vette won't start,bat good,have org. key,fuses ok,high beam light on lights off,lcd cluster won't light up?
Disconect the battery and ECM for FOUR DAYS then reconect the ECM and BATTERY. Let it sit for another four days without turning anything on. It should start but will run rough for about 200 miles as the ECM relearns the system. I had the same issue and that is what fixed it.
May 14, 2009 | 1994 Chevrolet Corvette
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
