Luxaire furnace blinks code 4 - Heating & Cooling
2 Suggested Answers
  • 1033 Answers
SOURCE: luxaire model 50a50 209
Check the 3-5 amp fuse on the control board, if the fuse is bad then there is a short somewhere in the low voltage circuit, usually in the thermostat wires. If the fuse is good check for 24 volts atbthe R and C terminal, if no voltage there then the board is bad and must be replaced.
Posted on Nov 26, 2012
The modal number and serial # for my furnace is MODEL # F+RPQ24HQ6A SERIAL # EEGS13264Q OUR FURNACE IS IN A METAL BOX AND WE CANT SEE THE BRAND NAME IS WE JUST BOUGHT THIS HOUSE BACK IN DECEMBER 2016
That's an older YORK product. The serial numbers are all coded by the alphabet. York or Luxaire parts house can help you. Probably about a 1980's unit. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Furnace won't lite
Look at the code explanation either on the inside of the door or thru a peephole in the panel. It will tell you what 5 flashes means.
don-ohio (:^)
Dec 21, 2016 | Heating & Cooling
I have a luxaire gas furnace and the gas valve keeps opening and closing. no codes when valve not connected, the voltage stays 24 volts. connected it drops out constantly
hmmm it seems like the luxaire furnace isnt able to tell if the valve is open or closed by electronic means try replacing the part and see if it helps
Dec 05, 2016 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
? 13:25
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
5 u code is on how to fix it
Here are error codes found on many York, Trane, Luxaire, Lennox, Carrier, ... If younotice 5 red colored flashes on your York Furnace, it signifies that your
Oct 03, 2015 | Cars & Trucks
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
Furnace quits with 4 blinking lights on panel
Most likely it's a sensor triggering the unit off. You need to have someone determine which lights are blinking (there is a code to them) and then find out what the code refers to. Could be a simple as dirty filters.
Mar 07, 2014 | Heating & Cooling
Coleman furnace bgm10016ax 4 blinks
Usually on a metal panel you have to remove to access the board there is an electrical diagram. On the side of that is usually a description of what specific blinking codes mean.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace installation
LUXAIRE MAKES NICE REASONABLY PRICED FURNACES IF MAINTAINED PROPERLY WILL LAST A LONG TIME EFFICIENCY RATINGS UP TO 98% IN THE FULLY MODULATING MODEL. ALSO LOWEST PRICED CONDENSING SINGLE STAGE ,PSC FAN MOTOR 95.5 % EFFICIENT. THEN THE ONE THAT I INSTALL THE MOST BEST VALUE FOR YOUR DOLLAR THE 2 STAGE VARIABLE SPEED MODEL 96% EFFICIENT .THE FAN IN THIS UNIT SAVES AN AVERAGE OF $ 135 A YEAR COMPARED TO A REGULAR PSC TYPE FAN MOTOR. BEEN INSTALLING LUXAIRE FOR OVER 25 YEARS AND HAVE HAD GREAT RELIABILITY FROM THEM.
Nov 05, 2013 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
