Question about Canon PIXMA MP830 All-In-One InkJet Printer
Message says to install print head and set the ink tank
While following the instructions to install my Canon PIXMA MP 830 printer I got the the section which says to install the print head. However, the print head seemed to have been already installed in the printer. I did not see an orange protective cap, so I went ahead and installed the three ink tanks. However, I still get this message to install the print head and set the ink tanks. I have already installed the software (Set up CD-ROM Disk) but it looks like I will not be able to print any document, until I resolve this error message. Should I take the print head out of the printer, and reinstall? If so, how do I take it out?
Please advise.
Sincerely,
Jeff Lambert
patjeff@tstonramp.com
Cell phone: 626-616-9401
  • Canon Master
  • 419 Answers
I'm guessing this MP830 is not brand new so I'm going to get you to reverse the process so we can check what's in there.
1. Remove the cartridges
2. Lift the grey arm on the carriage (the bit that holds the cartridges and printhead)
3. Gently pull the printhead forward and out of the carriage unit
From here on in you need to check that:
a) you have a printhead after all (if you couldn't find a printhead then this explains your problem immediately)
b) the printhead is not soiled on the back where all the electrical contacts are
c) that the carriage unit has all the copper pins in place and none of them are bent, broken off, or otherwise damaged.
If the printhead is missing entirely or simply not responding and there's no problem with the pins in the carriage (#3 above) then the simplest solution is to contact Canon and order a new printhead (ref: QY6-0061). Canon in the USA provide the cheapest printheads and I'm guessing that's where you're based.
Once that arrives, install properly and then you should (hopefully) be good to go... While you're waiting though, I'd recommend putting the orange caps back on the cartridge ink ports to stop them drying out.
Hope that helps.
Posted on Jan 26, 2009
I have an Canon MP 830 with error 5200. What can I do to fix it myself?
The error 5200 is either print head overheated or the logic board is faulty.
If it overheated, there might be burn marks on it somewhere or some distortion due to excessive heat.
Nov 29, 2013 | Canon PIXMA MP830 All-In-One InkJet...
CANON mp 830 NOT PRINTING BLACK EVEN THOUGH BOTH BLACK INK CARTRIDGE IS HALF FULL. i have taken the print head out, cleaned the contacts and still the same. what else can I do?
Copy machine makers are notorius for forcing users to use a bit of the more expensive color mixed in with black. I can't print in black, it is called greyscale, therefore it has color in it. If you only print in greyscale, you'll notice your color cartridges going lower over time.
Mar 01, 2013 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Mty printer is a PIXMA MP 470 it has an error code saying 'print head is not installed, install print head' It wont do anything or let me even go onto the menu??????
There are 2 ink cartridges that came with the printer (PG-40 and CL-31). These are the consumables that are also print head. You must install these in your printer.
Follow the setup guides/manuals that came with your printer. If you can't find them, they're downloadable from Canon's website.
http://support-ph.canon-asia.com/EN/sear...
hope this helps you.. please kindly vote.. thanks
May 19, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Hi, my canon printer pixma mp 830 does not print on cds. I seem to follow all instructions correcty. still does not work. can you help? thanks
Quite simply, the printer you are working with, according to the manufacturer's website, cannot print onto CDs.
I hope this helps!
May 04, 2011 | Computers & Internet
Appears to be printing but nothing on page
Let me lay down the possiable reason:
Blocked nozzel
bad print head
dirty print head
dried ink in cart.
OK I laid down some issues aboce invistgate them all and let me know right away. You can purchase a print head for this also you cna purchase print head cleaner,
did you run a allignment?
please od leave some feedback and ratings for your free answer today.
May 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Jan 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP 830 I replace purge unit
You may need a new printhead now, or you may have left a foam packing block inside the new purge unit.
Oct 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Prints every other line
Use the cleaning cycle first.If it completes do a nozzle check and then to align follow below.
You need to hook it up to computer to do a manual head align through the printer properties maintenance section.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
214 people viewed this question
old marine
old marine
