Question about Whirlpool WED5300S Electric Dryer
Not heating
It turns on but will not heat
    New Friend:
    Problem Solver:
  • 17 Answers
Most likely a heating element
Posted on Jan 21, 2015
Where is the on button to turn on the heated seats in a 2007 ford five hundred? I just got the car and I don't know where it is and I was told there was heated seats.
The heated seats are a luxury feature that heat the front seats. This provides maximum comfort for the driver and the front passenger. To turn on the heated seats, press the heated seat button, which is a picture of a seat. There are two of these buttons, and each are located on the center console. The button on the driver's side of the console controls the heat for the driver's seat, while the button on the passenger's side of the center console controls the heat for the passenger's seat. Pressing the heated seat button will turn the heated-seats onto their highest setting. Pressing the button a second time will lower the heated seats to their medium setting. Pressing the button a third time will result in the lowest setting. Pressing the button a fourth time will turn off the heated seats. There are three lights next to the heated seat buttons to indicate what setting the heated seats are on.
Tip
The heated seats will only work when the engine is running.
Mar 24, 2018 | Ford Cars & Trucks
The heat drops almost 10 degree before turning furnace turns on
Sounds like you have a heat pump.. One the pump can no longer extract heat from the air. the Furnance kicks in to supply auxillary heat ..I guess you have a set point for suxillary heat
Dec 28, 2017 | Honeywell Heating & Cooling
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Apr 21, 2011 | Honeywell Electronic Programmable...
I just turned on our heat unit "FA4A AC/Heat Pump"
There probably isn't a reset button=magic fix. With it in heat pump mode and tstat set above indoor temp, check your outdoor unit to see if it's operating. If not, check all breakers to it. Can you see any ice accumulated on the outdoor unit? If it is running and not producing heat, turn the tstat to emergency/auxiliary heat. and the heat pump turned off to prevent damage. You'll need a service tech.
Nov 04, 2017 | Heating & Cooling
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Central air and heat unit heat turns on for 1min and then heat turns on aux. heat
All aux. heat comes on when the thermostat calls for more than 2 degrees of the ambient temperature. Once the 2 degree gap is closed, aux. heat drops out of the circuit.
Some installers wire the thermostat to activate aux. heat every time heat is called for.In this wiring configuration the aux. heat stays on.
Apr 07, 2009 | Kenmore Heating & Cooling
Whirlpool WED5300S Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
