Question about Dryers
Dryer is not drying the clothes
If its the heater core. How to change it?
    New Friend:
If it is taking a long time to dry, but still has heat, try cleaning out under the lint trap. Take the whole lint trap off and clean the panel and path the lint is sucked through. I did this to mine and it made a HUGE difference! There was a ton of lint packed around the panel and only a small opening left where the air flowed into the exhaust.
With our dryer (Maytag) I had to take the front panel off to get to the area where the lint was.
Posted on Jan 19, 2013
SOURCE: my zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Posted on Mar 06, 2007
  • 351 Answers
SOURCE: tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Posted on Mar 05, 2008
gotgeek2
  • 565 Answers
SOURCE: GE Profile Electric Dryer Low Heat Problem
You may want to remove the back of the dryer to see if all of the element is glowing. Sometimes the element opens and then welds itself to the metal case, which would cause a partial, but not total loss of heat (slower drying time). If that is the case, part of the element will be glowing, and part of it will not.
Posted on Jan 25, 2009
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
  • 171 Answers
SOURCE: my dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Posted on Jul 29, 2010
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Gas dryer does not dry in "timed Dry" setting
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
MDE5500AYW Maytag Neptune not Heating
Sure I will help you when that happens that means that your heater core is no longer operating and when the heater core doesn't work when your dryer doesn't heat up anymore so that's your problem I hope I have helped you please leave a response or Stars if I have helped
Feb 07, 2018 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
Dryer is not heating up
This is a simple dryer design. The limits and heater are all mounted on the heater assembly. 9ce9b7a.jpgGet the front off and take a look see. AMANA DRYER
May 04, 2010 | Amana NED5500TQ Electric Dryer
Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Jan 30, 2009 | Kenmore 62602 Electric Dryer
Jan 25, 2009 | Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Tumble dryer wont dry
Mar 05, 2008 | Dryers
Dryers Logo
Top Dryers Experts
