Question about Bosch SHE3AR76UC 24" Ascenta Series Undercounter Dishwasher - Black
Bosch ascenta diswasher stops on clean cycle
My Bosch ascenta stops working when it changes to clean cycle and does not drain
catriver
  • 878 Answers
SOURCE: Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Posted on Aug 27, 2006
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
SOURCE: Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Posted on Sep 20, 2007
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
huuum
  • 750 Answers
SOURCE: Our bosch diswasher on auto
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Posted on Oct 05, 2008
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
DISHWASHER WON'T DRAIN ANLY HAD IT FOR 6 MONTHS. CLEANED FILTER. DID NOT HELP. WHAT TO DO?
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch SHE3AR76UC 24" Ascenta Series Undercounter Dishwasher - Black Logo
162 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
