Question about Compaq Presario Cq62-238dx Notebook Pc
My Compaq Presario CQ62 is really slow?
It is really running slow.It shutdown and log on super slow.
reyronald238
  • 57 Answers
SOURCE: how to open the screen of compaq presario
If you are unsure of this pls dont open the screen as it would add more problems. Better go to the service center and have your laptop check by a trained and qualified technician. This would certainly solve your problem and not adding to it.
Posted on Jan 30, 2011
  • 241 Answers
SOURCE: i can't remember my administrator
Forgot Windows 7 password? You can check out these 6 methods for Windows 7 password reset. It's helpful.
Posted on Feb 28, 2011
  • 1705 Answers
SOURCE: touchpad and extern mouse working
Try this website to down load a .pdf manual for your laptop.
h10032.www1.hp.com/ctg/Manual/c02641795.pdf
Look closely at the touch pad, in the top left hand corner of the pad you should see a little white led shining away.
Tap the led twice, it should turn orange, you've disabled your touch pad, to re-activate it, tap it twice again, this should bring the white led back on.
Posted on Apr 14, 2011
joecoolvette
  • 5660 Answers
SOURCE: my compaq presario cq62 wont turn on i bought a new power chord but it still does nothing
Shane, new power cord? Does this mean the old one was bad?
Do I assume you used a multimeter;
1) To test the voltage output of the AC adapter (Charger),
2) And had an assistant gently wiggle the cable TO laptop, and power cord TO AC adapter; to see if there was an intermittent reading on the multimeter?
[The Center Hole on the plug end of the AC adapter cable TO laptop, is the Positive connection. The outer cylindrical metal shell of the plug, is the Negative connection.
You should be reading 18.5 Volts DC.
An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. I have seen them on the checkout aisle racks, of large discount stores.
The Positive (Red) probe lead is inserted into the multimeter, in the Red hole that has DC Voltage next to it. (DCV)
The Negative (Black) probe lead is inserted into the Black hole ( - )
The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
IF there is more than one DC Voltage scale, the Function knob is set to the 0 - 50 Volt scale. { 0 to 50 ]
AC adapter checks OK?
Then check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the cable from the AC adapter is plugged into. (DC_IN)
AC adapter removed, ('Natch), and Battery.
Use a No.2 pencil, and it's eraser, to see if you can gently move the Center Pin, in the DC Power Jack.
ANY perceptible movement means replacing the DC Power Jack.
However good news. The DC Power Jack is NOT soldered directly to the motherboard.
It is a DC Power Jack that has wires coming from it, and the wires end in a small white plug.
This assembly is called a DC Power Harness,
All you have to do is partially disassemble the laptop, unplug the DC Power Harness plug from the motherboard, and replace,
http://www.amazon.com/Harness-COMPAQ-Presario-Pavilion-Series/dp/B004SFQA7U
USE AN ESD wrist strap, and connect it's alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving plate (Unpainted), on the table you are working on, and connect to it.
Or a large metal knicknack. (Unpainted)
Use a mutli-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up.
http://www.insidemylaptop.com/hp-g62-compaq-presario-cq62-disassembly/
(Just so you have it in case you need it for the future,
http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/ )
HP Support > Compaq Presario CQ62 series of Notebook PC's > Manuals > Service Manual, (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4188484&
Click on the first file listed -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC -
Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background)
AC adapter checks out, DC Power Jack checks out?
Check the Power On switch.
The Power On switch is pressed with the Power On Button.
The Power On switch is part of the Power Board,
http://www.ebay.com/itm/HP-G62-Compaq-CQ62-G56-Power-Button-Board-4EAX1PB0000-DA0AX1PB6E0-595204-001-/120845794823?pt=LH_DefaultDomain_0&hash=item1c22f87e07
This part separates the user from the tech. There are 6 wires in that flat cable. (I believe 6) There are 6 contact pins in the motherboard connector, for those 6 wires. TWO of those contact pins turn the laptop on. A tiny flat tipped Jewelers screwdriver, is used to MOMENTARILY touch the two contact pins.
{The Power On switch is a Momentary Contact Switch }
Laptop comes on you have a bad Power Board.
Laptop does not come on;
One or more Power MOSFETs may be bad, and may include bad Ceramic Capacitors (MLCC) for the Power MOSFETs.
Information using HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Yes, motherboard replacement
For additional questions, or to have me clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Posted on Nov 08, 2012
shaveen_shar
  • 8 Answers
SOURCE: My Compaq Presario CQ62-225NR keeps
The most and perfect way to stop this is by cleaning your computer virus. Scan your system and remove all the viruses.
Posted on Oct 21, 2013
I have a HP Presario CQ62 laptopo and I would put it as whennit came from the factory.What do I do?
read this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01867418&cc=us&dlc=en&lc=en
Oct 28, 2014 | HEWLETT-PACKARD HP Compaq Presario...
How can I make my Compaq Presario CQ62-112TU laptop a wifi hotspot?
Possibly not compatible witht the software you are trying to run.
Aug 01, 2014 | Compaq Presario CQ62-112TU
HP PRESARIO CQ62-219WM HARD DRIVE FAILURE ID: RLHK1S-5A36M4-XD002-61BW03
Here's a link to the Manual for your unit. Looks like these units are full of bugs, since many people are having problems with them. Good luck
Compaq Presario CQ62 219WM Notebook PC User guides
Jun 13, 2013 | Compaq Presario CQ62-219WM Notebook
Myi phone4 wont charge or sync music on my compaq presario cq62
Are you using iTunes? Are you using the Apple Cord to charge? It may be slow to charge on a computer due to low voltage at USB? Take a look at this : http://www.macworld.com/article/1150356/ipadcharging.html AND this: http://www.pcworld.com/article/260525/how_to_recharge_your_usb_gear_faster.html
Jan 31, 2013 | Compaq Presario CQ62-112TU
Presario cq62 keyboard not working
Hook a external keyboard to make sure it is working, if yes! the laptop keyboard will need to be replaced.
Mar 17, 2012 | Compaq Presario CQ62-112TU
My compaq presario CQ62 is stuck in logging off mode. I can't turn it on or off. How do I get out of this?
Hi, One thing you can try is disconnect all power soures. Battery and power adapter for 10 minutes.
Then reconnect power and battery. This will reset it to normal. Good luck
Jul 20, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
Compaq Presario Cq62-238dx Notebook Pc Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
