Question about Home
Landlord painted kitchen sing with enamel sink paint and now it is chipping off and looks terrible. How can it be fixed?
  • 5,245 Answers
Jan 2013
Remove paint with stripper maybe, otherwise Replace sink is only solution.
The etching and paint process for applying coatings to sinks and tubs is temporary fix, and will only last a year or two.
Report problem to landlord since he may have gotten a warranty on paint product, but don't wait for a magic cure to appear, because this is not magic, it's a failed paint job and paint has to be removed or sink replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jan 20, 2013
  • 19 Answers
SOURCE: CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Posted on Feb 02, 2009
  • 659 Answers
SOURCE: Chips in Thermocast sink
You might want to try an appliance touchup paint. You can find it at an appliance store or also at Home Depot. Just follow the instructions for it.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: Paint brush solvents stained sinks
Using solvents in a Thermocast sink is a huge no no. The company will have to buy you a new one. There isn't anything you can do.
Posted on Apr 01, 2009
Obertelli
  • 3006 Answers
SOURCE: belfast sink repair company in ireland?
Sorry to disappoint you, but unlike steel or cast iron ceramic sinks cannot be re-enamelled. To do so someone would have to grind off the remaining enamel and then reapply and re-fire the sink: not only would this be very laboiur intensive but the sink would be unlikely to survive the mechanical and heat processes involved.
If you can't live with your crazed or cracked enamel then buy a replacement sink. They're still manufactured as there is a demand for them.
Posted on Jul 26, 2009
SOURCE: a very small chip on our new porsaline hand basin
1) I was a painting contractor for many years.
Over the years, we tried touching up curtains and wallpaper and carpet etc.
2) You will have a very difficult time matching gloss and color of porcelain
Maybe semi-clear fingernail polish. Use clear polish and add a dab of white into the bottle ... see if it will shake up and make translucent polish >>
3) Personally I think 'paint' increases chance of making the repair much worse.
4) Whatever paint or fingernail polish you put on the spot will probably peel off easily if you decide it looks worse. But 'paint' can get into repair crack and be more noticeable.
5) Get a magnifying glass and look closely at why the piece doesn't fit.
Did the piece fit as well as it should?
Or is the glue holding it out?
If the glue sticks up a bit, then take exacto knife and surgically cut away glue.
Or use lacquer thinner or acetone and try to remove glue line.
I think acetone would be my first choice before trying anything else.
6) If repair is on side of basin, then live with it for a year and see if still bothersome. Eyesight and memory get worse over time.
The only thing we successfully touched up was outdoor brick and fiberglass roofing materials, mostly because they were outdoors and couldn't be inspected closely, and the surfaces were flat without any shine whatsoever.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 10, 2011
I have an old white refrigerator that works fine, just looks awful. What can I do to the face to make it look nice. I have wooden oak kitchen cabinets and a tile floor.
Paint it with white enamel.
Enamel Paint finishes in high gloss if you want that sort of finish.
Always paint in a dust free invironment with plenty of ventiallation.
With the expensive cost of many home appliances, sometimes replacing an old refrigerator is out of the question, especially if it still works well.
This can be a problem if you've recently painted your kitchen or if you're just sick of looking at an old, outdated fridge.
Instead of learning to live with your boring or unattractive refrigerator, you can give it a bright new look with a few coats of paint.
Mix a few tablespoons of vinegar into a bucket of warm soapy water.
Use this mixture to clean the refrigerator.
Scrub away any grease, dirt or other grime with your soapy water and a stiff bristled scrub brush. Wipe the refrigerator dry with a towel when it is clean.
Use painter's tape to cover parts of the refrigerator you do not want to paint such as the handle or the grate at the bottom of the refrigerator.
Apply a coat of appliance paint to your refrigerator with a paint roller to prime the surface.
You can also purchase appliance paint in a spray can and use it to spray paint your refrigerator.
Sand the paint with an extra fine grit sanding sponge when it is completely dry.
Try to make the surface as smooth as possible and then wipe away any dust created with a clean towel.
Paint the refrigerator with an enamel paint tinted to the desired color and a paint roller.
You can use oil-based or latex-based enamel depending on your preferences.
Oil paints usually have a stronger odor than latex paints but they may last longer.
Apply a second coat of paint when the first coat is completely dry.
Sand the final coat of paint when it is dry with a wet extra fine sanding sponge.
Spray the refrigerator with water while you work to keep it damp and keep sanding until the paint is smooth and shiny.
Remove all of the painter's tape from your painted refrigerator.
Sep 08, 2013 | GE Refrigerators
Where do I find high temp paint to use on a gas stove?
Auto parts stores have manifold and engine paints for high temp use, or the hardware store has barbecue and wood stove paints, usually black. Your stove may have been enameled (Melted glass powder process, like ovens, old sinks and bathtubs).
Jun 05, 2012 | Kitchen Ranges
Can I repaint a steel enamel finished sink? Has been scratched by clumsy wife!!
Yes you can. they make several products for this at the harware stores. You said enamel but are you refering to porcelain? To do the repair you will need porcelain repair compound and some high-gloss, alkyd-base paint that matches the color of the porcelain. if it is simply enamel then just match the color or repaint the whole sink using enamled paint. what you have to watch and worry about is if the repaired section will be contantly wet, if water gets under the paint it will bubble and flake off and make a mess. So the answer is yes but it may not be worth the trouble.
www.diybathrepair.com
Sep 12, 2011 | Microwave Ovens
I have a cast iron wood stove that needs to have enamel repaired
They actually sell ceramic paint to repaint these. It should be available at your local hardware store. I repainted a claw foot bathtub with the ceramic paint kit and it looks like new again. If this helps please leave feedback...
Mar 12, 2010 | Heating & Cooling
Can ~i respray the top of my Aga cooker with heat resistant enamel paint
yes but it will soon peel of you will need to chip off all the glass enamel first to give the heatproof paint something to stick to, use 650 degree paint
Nov 23, 2009 | Kitchen Ranges
I have some chips on a Findlay cookstoves enamel.It is old and the enamel is light green.Any ideas where I may find something to touch it up?
There are several brand of touch-up enamel paint for appliances. Krylon for example, it's carried by a wide variety of retailers such as Home Depot, K-Mart, Sears and Walmart.
You can also get it at store that specialize in paint like Sherwin Williams. They might also be able to give you the best match to your color. If not you can try appliance stores. They may be able to give you a good match. The only other option is to match it yourself. The best way to to that is to get some color card examples from a paint store or hardware like Home Depot and find the best match. Now get a list of the colors that they use to mix it. Ask if you can get a very small amount of the colors used in the mix and using trial and error mix it yourself.
You can also try mixing it to get your color using enamel auto touch-up paint.
There really is no source for old appliance touch-up paint so it will never be perfect but with a little trial and error you can get pretty close.
Hope this helps you out.
Prep before painting:
  • Sand the damaged area lightly with fine-grit sandpaper. Roughen the area to be painted and remove any rust, but avoid sanding the surrounding surface.
  • Clean the area thoroughly with a rag dampened with paint thinner. Let dry.
  • Paint over scratches with appliance touch-up paint, using the bottle's applicator brush or another fine-tip paintbrush. Let dry overnight.
There will be issues with areas that are exposed to high heat so be prepared to repeat when necessary.
Nov 13, 2009 | Stoves Kitchen Ranges
How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Oct 10, 2009 | Ovens
Paint chipping of the inside of door of my sylvania microwave . There is bare metal under the paint .You can see how this is an issue.The warrenty numbers in the product manual are all disconnected...
well apart from replacing the door if clean the old paint away then you can paint the door with an enamel paint the colour of your door but it must enamel paint or microwave paint gd luck
Oct 06, 2009 | Microwave Ovens
Paint on stove top is coming off.
with smaller spots you can use appliance touch up paint and it should hold paint down and keep spots from getting bigger. Depending on how old the range is your landlord might be able to order a new top. I would voice my concern to the landlord and see what they might be willing to do to appease your concerns.
Jan 16, 2009 | Sears 61301 Gas Kitchen Range
LG phone paint chipping
Ok I have seen great results using the paint from Automotive "Touch Up" Spray cans.. OR those "Automotive "Touch Up" sticks.. providing I guess ya can find the right color? Anyway G L.
Aug 09, 2007 | LG Jabra Winder - Earboom for Most...
Home Logo
101 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
