Question about Toys
I am not sure what model Air Hog helicopter this is. The husband tossed the instructions. -_- I'm wondering what that thingy is that has the metal plug in thing on it. Where does it go? A radio? My ce
    Genius:
  • 1,669 Answers
Try these references:
http://www.airhogs.com/
http://search.aol.com/aol/search?&s_qt=sb&q=Air+hog+helicoptor+manuals&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 19, 2013
5 Suggested Answers
  • 7 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Posted on Feb 15, 2010
  • 4 Answers
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
  • 3 Answers
SOURCE: Purchased Helicopter MINI AIR WOLF
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Posted on Nov 15, 2010
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
My Air Hog Black Ops helicopter blades do not spin. It is charged as lights on helicopter and controller work. I have tried setting controller to all 3 channels with no luck. Any ideas?
check over the helicopter first then hand controller
heli
could be the receiver chip or pick up on the helicopter
motor issue ?
didnt think it was direct drive .might be
have to chase a broken wire connection or other
if cogs or belts are used ..stripped or jammed or other
receiver
toast
Jun 18, 2016 | Air Hogs Havoc Heli Helicopters
Hello, i just bought a Sky Force helicopter for my husband. i was wondering if i could buy a wall charger instead of using the remote for charging it. and if so how many volts and amp? thanks!
I am suspecting it would have come with a usb cable as well to charge the helicopter something like http://www.hobbytron.com/SpareUSBChargerForRaptorRCHelicopterZX35632.html
If this is the case you just need a usb charger
just type inot google usb ac adapter
(make sure voltage matches supply voltage if USA its 120V 60 HZ AC where as in England , Australia its 240V AC)
also check with hobbytron to see this charger suits the model helicopter you have
http://www.hobbytron.com/ChargingCordForGYROHerculesRCHelicopterZX35850.html
Dec 25, 2014 | Sky Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
How do you download videos and look at throgh the camra on the helicopter?
Thank you for your question. From my research, it appears that the Air Hogs R/C Reflex does not have video capabilities. The Air Hogs Hawk Eye does have video and picture taking capabilities. Look at your Air Hog to determine which one you in fact have. Here is a link to video tutorials for all of the Air Hog products that may help you: http://www.airhogs.com/#/need_help/reflex. The link is set to the Reflex but you can change your product selection to any product at this link.
If you have the Hawk Eye, here is a link to the instructions: http://www.spinmaster.com/files/instructions/AH_Hawk_Eye.pdf. It is not possible to look through the camera. You can however, take pictures and videos during flight. Download the images on your computer to see the images you caught. To download, plug the small end on the USB plug (included with your Air Hog) to the product and the large end to your computers USB plug (this is how you charge the Air Hog, too). In your computer's Windows Explorer, you will see your Air Hog connected and can copy the images to the computer. Remember to remove the images from the Air Hog to free up space for new images. Always remember to pick on the eject button on your computer for the Air Hog before unplugging it from the computer. Take note that the videos do not record sound. If you access www.airhogs.com, you can register and download free editing software to add cool images, sounds and words to your videos and pictures. You will also be able to share them with others.
If you need additional assistance, you can contact Air Hogs Flight Training Center at 1-800-622-8339.
I hope this helped. I would appreciate your taking the time to rate my assistance with FixYa. Enjoy your flight!
Jan 23, 2011 | Air Hogs Reflex Micro Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
How do i fly my spin master air hog rc helicopter all it does is go in circles
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Heli spins counter clockwise
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
Jan 03, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Controling problem
Glue the metal pin in the hole of the potentiometer. But use some good glue. I had the same prob.
Apr 26, 2009 | Spinmaster Air Hogs CHLD Twin Thunder
Toys Logo
292 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
