Question about KitchenAid KGST307 Gas Kitchen Range
Spark igniters on the burners fire continuously
I have a Kichenaid (Whirlpool) thermal-convection freestanding gas range model KGST307GBS0. The spark igniters on the surface burners just started sparking continuously, regardless of whether the burners are turned on or not. I can light none, one, all, or any combination of the burners but the igniters keep firing. I thought that perhaps something had gotten wet during cleaning and left all four burners on for about 10 minutes but to no avail; the igniters kept sparking. We also tried baking something for about 90 minutes or so but the igniters just continued to fire (fortunately, I was in another room or I think I might have gone bonkers). I turned of the circuit breaker for several hours to stop the incessant clicking but it just started up again once power was restored. I am assuming the igniter module (found in the parts list of the chasis diagram) is bad but hesitate to spend $100+ if there is another option. Any ides???
  • 3 more comments
  • Guy Cardineau Jul 16, 2007
    Cat,
    I was hoping you might respond since you helped me with this range before. Thanks for the suggestion. This solution occurred to me and I have already attepmted to check this possiblility. I removed the control panel cover and disconnected one wire to each of the valve switches but the igniters continued to fire. I suppose I could/should have disconnected each switch completely and will try that this evening, unless you have another method to suggest for checking the switches. Meanwhile, we're cooking outside!
    Guy
  • Guy Cardineau Jul 17, 2007
    Cat,
    I disconnected both wires from all four switches and the sparking continued. Any other ides?
    Guy
  • Guy Cardineau Jul 19, 2007
    Still looking for a solution to the problem of the sparking burner ignitors. Any further ideas???
  • Guy Cardineau Jul 20, 2007
    Cat,
    Complete model number is KGST307GBS0.
    I removed the front console cover and disconnected both wires from everyone (that is, all four) of the burner switches and the sparking continued. I was curious and put a meter on each set of two wires and it spiked every time the sparks would fire at the burners. I have not checked the wires from the switches to the ignitors at the burners but will do that (if I can figure out how to expose those wires). Is the spark module behind teh stove or underneath the oven above the drwaer area? It's not real clear from the PDF pictures I have from KitchenAid.
    Thanks much for your help.
    Guy
  • Anonymous Mar 30, 2014
    I have a 5 burner DSC range. Two of the burners (the ones I have used the most) continue to click after the burners have lit. I tried cleaning them as suggested and then replaced the 5 Point igniter unit. This didn't change anything so I think that I blew 100 bucks for a unit that I didn't need. Is there a way to determine whether the sensors that tell the igniter to stop firing are faulty? Is there any advice for cleaning them better? Finally, how does the sensor actually work? Thanks!!
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Posted on Aug 18, 2007
    President:
  • 878 Answers
Guy, I would suspect one of the valve switches is shorting. Probably got wet and is grounding. Before you go after the spark module check these first. Each control valve has a switch. I usually find these to be the culprit with constant spark. Catriver.
Posted on Jul 16, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek Jul 16, 2007
    Right on Guy, they run in a series. Start with one and work your way back. Look for one that might be grounding to the manifold. Or one just might be shorted. When the sparking stops, you found your culprit. If not, we'll have to go from there. Usually when the module fails, it's a no spark deal. Catriver.
  • Ron Marek
    Ron Marek Jul 20, 2007
    Guy, Im having a rough time coming up with a wiring diagram of this model. There should be 3 more letters and a number following the kgst307. You are sure that none of the wires going to the switch's or ignitors are grounding to the cabinet. This is direct spark ignition. On the spark module you should have 4 wires going to the top burners. Three others for ground, bake and broil. Try removing, one at a time the wires going to the top burners. It's possible it could be the module, but I rarely see it. Catriver.
  • Ron Marek
    Guy, according to what I see, the module is in the back, inside bottom, left hand side. Catriver.
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Oven turns off while baking
There is a service flash, W10622771, for gas ranges of your model number--the bake burner ignitor is not lighting the gas--it's a direct spark ignition type. The ignitor is sparking but no ignition. Possible causes are (1) Wiring harness might be pinched between the bake/broil ignitors and the DSI board. (2) DSI mounting bracket may be contacting a solder joint on the back of the board. (3) Positioning of the ignitor and gas burner ignitor ports may be out of adjustment. (4) Ignitor electrode deterioration
Facing the range, the DSI board is behind the control panel on the left side, mounted in the bracket.You'll have to remove the back cover to expose the boards. BE SURE TO UNPLUG THE RANGE BEFORE DOING THIS. I can provide diagnostic mode if you want to proceed further.
Aug 09, 2015 | Maytag MGR8700DH MGR8700DH 5.8 cu. ft....
Top burner igniters
The spark module was damaged when you lost power and will need to be replaced. Here is that part to order.
Whirlpool W10331686 Spark Module AppliancePartsPros com
There is also a video on that same page to show you how to make the repair.
Mar 03, 2014 | Amana 30 In. White Freestanding Gas range...
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
The burner igniters continuously click.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Oct 05, 2010 | Maytag Gemini 30" Self-Cleaning...
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
KitchenAid KGST307 Gas Kitchen Range Logo
759 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
