Question about Nikon Speedlight SB-800 TTL Flash
Sb 800 and sb900 overexposing
I am using both a sb 800 and 900 on a d200. The 900 after shooting about 75 images sounded an alarm which I believe is to alert over heating. I was using new alkaline batteries at this time. I shut it down and restarted it and all seemed fine until this weekend on another job when half way through a wedding it started to intermittently blow out images. I tried using it at all camera settings, changed flashes to the 800 and I continued to have this problem. I can not figure out what is happening. Any help would be appreciated
  • umberh May 11, 2010
    What a nightmare! I'm assuming you have, but just to make sure:
    Have you checked your bracketing settings? If it is an intermittant blow could you be seeing the effects of the bracketing?
    Problem Solver:
  • 14 Answers
It might be you are not making a good contact on your camera and flash .
Are you using a cord to get the flash off the camera . If so the cord could be intermittent .
Posted on Apr 11, 2009
Are the sb-900 and the sb-800 heads the same? I have a sb-800 and I want to buy teh coco ring flash with the sb-900 adapter, are both the same, will it fit the sb-800?
No it is not the same. the SB 900 is 25% bigger.
I just got a Coco ring for my SB 800 (I bougth the one for the SB 900) and it is big. But I just filled the empty space with hard foam and works wonders. I can post a photo if you want.
By the way I have a D 700. It migth fit different in other cameras.
Jan 13, 2011 | Nikon Coco Ring Flash Adapter(49368824316)...
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
atdlee@netzero.com
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
272 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
