Question about Compaq Inkjet IJ600 Printer
My compaq if600 is printing too small and layering
What dual layer burner can i put into my compaq nx6110
It may not fit, some dual layer burners are made to fit a particular laptop.
You maybe lucky if it does fit.
Feb 27, 2013 | Compaq Computers & Internet
How to fix cracked PCI board in a amplifier
If the PC board is a single layer board then you can remove the coating on the printed circuits either side on the crack and then solder a small piece of wire on the printed circuit tracks. This will bridge the printed circuits across the cracks.
If the PC board is a multi-layer board then it is impossible to repair and the PC board needs to be replaces if you can get one. It maybe cheaper to get a new amplifier.
Feb 14, 2013 | Motorola Mobility KRZR K1 Motherboard Flex...
Do my compaq presario cq50-209 have a dvd burner?
The easiest way to tell is to open up "My Computer" and look at the drive. If it says "DVD-R," "DVR-RW," or maybe even "DVD+R," you have a DVD burner. If it says DVD-RAM, then it just reads DVD's.
Feb 28, 2011 | Computers & Internet
PCLinuxOS live-DVD will not boot. Grub loads OK,
You may be trying to load a dual layer DVD on a single layer or older dvd drive. That PC should run PCLinux perfectly.
Mar 05, 2010 | CMT Hewlett Packard-COMPAQ DC7900 C2D/3.0...
THe motherboard on my Compaq presario c714NR notebook has a crack. Can the motherboard be repaired? If not, where can I purchase e a new motherboard?
It is impossible to repair cracked motherboards because these boards are multi-layer circuit boards and you cannot get to the printed circuit track in the inner layers of the board.
Oct 12, 2009 | Compaq Computers & Internet
Dvd
Compaq information can be found by doing a product search on either the Compaq website or the HP website.
The model number you have given is not enough to narrow down your machine. I have included a few of the CQ60 series machines I found with a simple search. In both cases the answer is "yes you do".
CQ60-228US version
Multimedia Drive
SuperMulti 8X DVD±R/RW with Double Layer Support
CQ60-222EZ version
Multimedia Drive Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
You can find the rest of your model number by searching the label under your machine. Then search the HP or Compaq site to find all your specs, updates etc.
Good luck and have fun with it.
Sep 01, 2009 | Compaq Computers & Internet
Print is too small
try to cahnge the paper setting to A4
Jun 08, 2009 | HP Compaq Presario SR2150NX PC Desktop
Photoshop, separating gray shades
I'd select the different levels of gray, and cut the color out of the picture, then paste it into a new document, using the exact same document and canvas sizes each time, so that you end up with three or four new documents, each with a different level of grey. If you're familiar enough with PS, you can do so by adding four new layers, and simply copy and paste the colors to four separate layers, and just hide all layers except the one you're printing currently. PS will ignore all layers that are invisible when printing. Click the 'eye' icon on each layer so that all of them are hidden except the one you want to print.
Hope this will FixYa!!!
Jun 01, 2008 | Adobe FC Photoshop CS V8.0 for mac
Compaq Inkjet IJ600 Printer Logo
21 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Greg Cann
Greg Cann
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
