Question about Kenwood KAC-8104D Car Audio Amplifier
Can you bridge
How to bridge
  • 341 Answers
It can not be bridged, it is a one channel amp!
Posted on Jan 20, 2013
Why every time i look for garden bridge for new ideas, i get something about a bridge in London?
There is a new project that has just been designed and is waiting to be approved, for a new bridge crossing the Thames in London. This bridge will be called Garden Bridge as the project involves several trees and plants. The bridge will be only for pedestrians and it will be like crossing a garden.
Here are some pictures of the project
Jan 08, 2014 | Garden
Can i get personalized garden bridges?
Yes, you can either request a customized garden bridge from garden bridges' shops, designers, websites etc. Or you can ask someone with some skills in the woodwork field to make one for you following garden bridge instructions from the web, and your own instructions for the customizing
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
Reset bridge to different router without the disk.
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
Oct 01, 2010 | Computers & Internet
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
D-Link Di-604 bridge?
I had no problem finding the Di-604 on the D-Link site.
http://support.dlink.com/products/view.asp?productid=DI%2D604
Dec 16, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Jun 02, 2008 | Audio Players & Recorders
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Kenwood KAC-8104D Car Audio Amplifier Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
