Question about Linksys Wireless-G Broadband Router
Password for the Linksys Wireless Router
Where can I fine the passkey or the password for my wireless router?
  • John Hong
    John Hong May 11, 2010
    Are you trying to connect wirelessly to the router or are you trying to access the web management interface to configure the router?
    Novelist:
  • 176 Answers
If you lost or forgot your pwd you have to reset your wireless router over and do a new connection. Routers generic pwd is admin
Posted on Jan 26, 2009
  • 56 Answers
Power down the linksys and on the back is a reset button push it. The ones i have installed dont need a pass word or key,if it is asking you try the info you used from your internet provider ( e-mail address or access #s)Also try skipping this step and see if it will let you go on to the next part,Lynksys advisor has major issuses with it I dumped it from all the pcs I installed.
How do you enable security for linksys wireless routers
  1. Type "http://192.168.1.1" into your Internet browser, and press "Enter."
  2. When login page opens up, type the username and password for your wireless router.Depending on your router brand, you may have "admin" and "password" as the respective default username and password. But again, you must refer to your wireless router support manual.
  3. Once logged in, click "Wireless Security" and Select "WEP" as the security encryption type
  4. Set the default transmit key to "1".
  5. Type in a passphrase and click "Generate". This generates random passkeys.
  6. Note down your network's SSID (listed on the security page) and the first WEP key. This is the information that you will need when trying to allow new connection through the wireless network.
Aug 22, 2012 | Linksys Computers & Internet
Can't use wireless due to possibly forgot password.
If you do not have the Network SSID and Passkey, you will need to logon to your Router (via a cable connection) as an administrator to get the information from the Wireless Security setup screen.
The other way, would be to look at another PC/LAPTOP/SMARTPHONE which can connect to this Router and look at the Wireless Setup SSID , Encription (WEP or WPA or WPA2, etc) and Passkey. Passkey is normally not displayed but there is usually an option to 'display the characters'.
Hope it helps and good luck!
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
I have forgot my passkey for others to connect wireless - how can I change the passkey?
So you've lost the password that you set up for your linksys router and no one remembers it. Generally you can do two things. Buy a new wireless router or you can reset the router to it's factory default and then save the password before you forget again.
Dec 27, 2010 | Draytek Vigor 2600VG Wireless Router...
Can you send me instructions on how to secure my linksys 2.4GHz router so no one can access it from another location
Hello
Ok, at the link below you will be able to get instructions on how to secure your Wireless network.
Click HERE to navigate to the page.
Kind regards
Andrea
Aug 14, 2010 | Linksys Wireless-G Broadband Router
How do I find the passkey for my router....I am trying to get my wireless printer to work and it id asking for my passkey and I don't remember any passkey?
usually the passkey will be found in the bottom of router, named as wep key...
you can log in to the router interface by typing the ip address of your router in any web browser, and you can find what is the password...
the ip address of linksys router will be 192.168.1.1
it will never change unless u changed the ip address of your router manually...
Aug 11, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I do not remember the passkey code?
You can reset the Linksys back to the factory defaults and the login to the wireless settings and create a new passphrase key.
Power up the router and press the pinhole RESET button at the back of the router for 30 secs.
Open a browser and enter the configuration URL enter the default login and password, you should change the password then go to the wireless settings to change the encryption passphrase and SSID etc.
Aug 07, 2010 | Linksys WRT110 Wireless Router
New password
In order to enter passwords, and secure your wireless network, you must log onto your wireless router's configuration settings page (the webpage used to initially setup the router). To get to this page, you must enter the router's ip address (192.168.1.1 by default for Linksys routers) as the url (i.e. http://192.168.1.1). Once you do this, you will be asked for a username and password (Username: admin, or <blank>, and Password: admin, by default). Successfully logging in should bring you to the router's settings page. From here, you can go to the administrator tab, change the login password**, or go to the wireless tab, wireless security sub-tab, select a type of encryption if desired (WPA2-Personal/PSK or WPA recommended), and set the desired passkey**.
**NOTE: When changing settings, before going to another page, make sure to click Save Settings at the bottom of each page to keep the settings.
Here is a page to help with what you can do in order to secure the router further.
Mar 11, 2010 | Linksys Wireless-G WRT54GS Router...
Cant connect to the internet on my laptop
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
2. pull up ur browser then type at the url:192.168.1.1. or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password, just leave it blank
3. it will show the setup page of the router. u can set the router on the specific internet setup that u have. look for the wireless settings once u are on the wireless settings of your router, it will show the type of security and the password that you create..
if you have any querry pls feel free to get in touch.. good luck
Sep 01, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Forgot security key/passprease
the security passkey or passphrase will be found on the router user interface. if you are also using a linksys wireless router...you can try this out..
1. open internet explorer...type 192.168.1.1 on the address bar and hit enter.
2. it will ask you for a password, default username and password for a linksys router is username - nothing, password - admin.
3. go to the wireless settings tab and wireless security tab then look for the password.
Oct 08, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Wireless g router
which passkey? if it is to access the router utility, it is usually password or password1 if it is to access it from a wireless device, then it is whichever number is listed as WEP or WPA
Jan 09, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
