Question about Craftsman 10" Table Saw
Mod # 113.221610, what is the arbor size on the 8" blade
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: My saw problem has to do with changeing the blade.
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
Posted on May 17, 2010
I need to buy a fine tooth blade for my Workzone drop saw. Say 80 teeth
the circular blades for all compound saws have two important specifications. 1. the arbor size (the center hole in the blade and the diameter of the blade (usually 10" or 12"). After determining that you can choose the number of teeth on the blade. Not all blade manufactures offer every diameter, arbor size, and number of teeth.
Feb 07, 2018 | Blade Saws
When i changed the blade on my dewart dw706 chop saw i think there was something in the 1 inch arbor of the saw to reduce the size of the arbor. I tried reversing the washer but the blade still does not...
Sounds like you lost the blade adapter ring
Blade Adapter RingPart Number: 152636-00
You can get one from Epartsreplacement.com on this Page They are in stock and cost $2.33
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 01, 2011 | Garden
We have a master craft 12inch maximum dual bevelmitre saw with laser, came with a 12 inch blade with a 5/8 arbor, apparently they don't sell 12 inch blades with 5/8 arbor, only 1 inch. apparently saw...
You need a saw blade bushing. It looks about like a wedding ring with a 5/8 id (inside diameter) and a 1 inch od (outside diameter). I did a quick google search and found this: http://circlesaw.com/xcart/1-to-5-8-Saw-Blade-Bushing-p-5036.html
Good luck. Please vote if you found this helpful.
May 27, 2011 | Garden
I have a Sears 10 inch bench top table saw. Model 133221770. purchased in 1998. Lost the ''collar blade''. Sears stopped making the part, can I substitute or where can I find one?
If you can measure the arbor size, (the spindle the blade goes on), just buy any collar that will fit. The basic purpose of the collar is to spread out the force over a larger area of the blade from the arbor nut when it is tight.
Jun 08, 2010 | Craftsman Saws
Blade shaft slipping
It could be a number of issues. These saws have a built in vari-torque clutch used to prevent kickbacks. Basically, when the blade binds while cutting, the arbor spins but the blade won't (prevents kick-back). It works by not over tightening the blade washer (this is the slip clutch), if you over tighten, the blade washer can't prevent kick-backs because it has no room to slip, if you under tighten, the arbor spins, but the blade won't. I'd try to tighten the blade washer 1/8 turn and see what that does. If your actual arbor shaft is not spinning, you could have a gear issue. If you hear the motor running and the arbor slips (not the slip clutch) sounds like there might be a gear issue,If the rotor is spinning (the part inside the stator-i.e. the electric motor section) but it is not transfering that movement to the arbor, it has to be a gear issue.
Jun 07, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
The blade spins to fast and torque is very low. What do I replace
If this is a belt driven saw, maybe the pulleys on the motor and arbor are reversed? If both pulleys have the same size hole and the one on the motor is larger than the one on the saw arbor, then you should switch them. This will lower the RPM and increase torque.
If this is a direct drive saw (the motor shaft is the saw arbor) then the only recourse is to use a smaller blade.
Feb 17, 2010 | Bosch 4000 Factory Reconditioned 10"...
Blade becomes loose after 4-5 cuts
Check to see if the arbor, nut or spindle is worn. You may want to get a new shouldered nut for it. Also see if running loose has damaged the shoulder on the spindle. Check that the correct size of arbor is being used on the blade.
Jan 19, 2010 | Craftsman 10" Table Saw
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Size of hole in 10inch blade for dewalt power workshop radial arm saw
Most 10" saw blades are bored to fit a 5/8" arbor.
Unless someone has changed the arbor on your saw, I'd say that's 99% sure to work.
Are you making your own blades, or accessorizing? In any event, start with 5/8" and see where that gets you.
If you find this helpful, please take the time to rate my post. Thanks!
Mar 10, 2009 | Delta Machinery 10" Professional Radial...
Craftsman 10" Table Saw Logo
89 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
