Question about Kenmore 24032\24036 Top Load Washer
Wash machine will not spin
The wash machine will wash fine and will drain all of the water in the tub fine during the spin cycle but will not spin during the same cycle. I have verified that the contact switch is working correctly and you can hear the motor running and vibrating during the spin cycle but you do not witness any spinning activity. Please provide any other insight...Does the motor operate off of a belt and could there be a broken belt?
  • Anonymous Nov 12, 2007
    I've got the exact same problem. No spinning. Makes the noise like it is spinning, but it is not. Drains all the water out too. You said it was a problem with the gear box and the contacts. What do I look for once I get the front panel off? I replaced the temperature switch and that's when this problem occured. Is it possible I disconnected something?
  • Anonymous Mar 29, 2014
    the motor doesn't turn on during the wash cycle or the spin cycle
Sounds like a problem with the coupling between to motor and the gearbox!
Posted on Jul 16, 2007
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Water does not drain during spin cycle. Tub spins, but water remains in the tub.
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Apr 18, 2014 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse wash cycle not engaging
Likely transmission failure. The motor controls agitation as well as draining
Feb 26, 2013 | Washing Machines
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
331 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
