Question about Toshiba 36A50 36" TV
Toshiba 32'" tv wont give sharp picture
Screen looks like tv that needs antenna adjusted on it to give clear picture.
My other tv has a clear and sharp picture. we are plugged into cable
  • Anonymous Mar 31, 2014
    tv has lost picture on dtv but we have a clear picture on it when going through our recorder on dtv we have a dark grey screen and it keeps flashing (no signal)the aerial from outside co ax cable goes to recorder then to dtv
    Problem Solver:
No rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Posted on Jan 28, 2009
My sharp model lc-20b9u-sm has a dark circle on screen
Without seeing the dark cycle myself it is difficult to guess what. I only can think of something hit the screen (ball?) or perhaps someone bumped into the screen?
If the bump was minor, it could become lesser.
Perhaps you should ask a technician to look, or take a picture from the screen, one when switched on and one switched off, but close to where the dark circle is and take the pictures to a tech.
Jun 26, 2014 | Universal Premium Wall Mount For Model...
My sharp tv lc-20b9u-sm there is a dark circle on screen when there is picture or antenna off
Can you include a picture of the screen here; Johson? If so, it will be more helpful to provide a solution to this problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
Sharp 32 inch lcd tv won't reconginze channels when connected to antenna. Why? The screen now looks like a defragmenting on a computer screen.
You probably need to do a channel scan to find TV channels and progrma them to the TV memory. Using your remote control select Menu mutton and follow instructions for "auto channel scan"
Jan 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
NOTHING BUT SNOW ON THE SCREEN
Are you connected to cable TV or an outdoor antenna? If on cable TV check the signal on another TV or if on an outdoor antenna you will need a digital TV adaptor to pick up local stations due to them not being available in analog anymore. Please take moment to rate my answer. Thanks...
Nov 26, 2009 | Toshiba 32D46 32" TV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Toshiba televsion is saying digital channel signal strenth is low
if you're using antenna, (most likely)you need to adjust your antenna to where it picks up the best signal. The picture comes in clear with good audio and doesn't pixelate often.
Feb 06, 2009 | Toshiba MD14FP1 14 in. TV/DVD Combo
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Sharp 20f640 focus problems
At the rear of the tv there may be two controls on the right hand side marked "screen" and "focus".If the set is newer,you will have to remove the cover and look to your right.You will see a dark object with a black or red wire coming out of it's top.That is your flyback transformer.On this you will find these two controls.Adjust your focus with the one so marked.Be careful to only adjust this control while you watch your picture clear.PROMPLY put the cover back.
Feb 10, 2008 | Sharp 20F640 20" TV
Toshiba 36A50 36" TV Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
