Question about Emerson Black Microwave Oven
Panasonic microwave oven nns952wf runs when door is open
I have a panasonic microwave oven that continues to rotate the plate and fan when the door is open. I know magnetometer is not switching on since I place a cup of cold water just to see if it would heat it up and it does not heat up the water. Has anybody run into this?
Yep going through the same thing myself. I found that the OMRON switch V-16G-3C25-M is bad and now I'm trying to find one. I contacter OMRON but they said the switch can only be orded from panasonic so I'm going that route myself. If I have any luck I will write back.
Posted on Jul 22, 2010
    Problem Solver:
  • 7 Answers
If display ( : ) after 3 sec replace converter bord and if display ( ; ) after 23 replace magnetron
Posted on Apr 27, 2009
My panasonic micro-oven is working but the fan and turntable are not operating.
HI.oven has a small DC motor thats turns the turnatable..Now if turntable does not rotate then yuo need to remove the bottom cover of the oven..Unscrew it and check if motor is working ..You can check continuity of the motor using a MULTITESTER..If it is short-circuited or not.Hope this helps.FAN and turntable is being run by this DC motor..Hope this helps.
Jul 14, 2011 | Panasonic Microwave Ovens
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
Any Panasonic parts not available locally can be had here:
We appreciate your thoughtful rating of our answer.
Nov 03, 2007 | Samsung SMH7159 Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Emerson Black Microwave Oven Logo
460 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
