Question about Gateway M360X Notebook
Hitting the F11 key by mistake when booting up
When booting on today my granddaughter hit the F11 key and I lost all my files. Any suggestions?
  • Gateway Master
  • 32,281 Answers
Try this.
Press F8 key (several times) as you boot up.
Then select Last Known Good Configuration
Hopefully you can then see your files.
If you can then back them up, you should do this regularly in case the hard disk fails.
Posted on Jan 26, 2009
  • Gateway Master
  • 4,806 Answers
Data recovery!!! its the only way, you have to send the hard drive away and its expensive, sorry
Kind regards
I have a hp paviliona1340n and the screen comes on an shows the hp logo,but then the screen goes black and says reboot device and press any key, what can i do to get my computer running back to normal
a1340n,windows what?
this pc Desktop is now retired at HP, no support. 12 years old now.
that depend on 2 things what is wrong.? (hdd or OS dead)
came new with XP the dead OS>.
if you have the HP hot key f11 working
or of you have the HP install media kit for it.
i guess the screens ok, and BIOS is OK, hit the bios key yet? power on hit what the screen tell you, at power on.
if that works and the OS fails to boot?
that means the startup files are bad on hdd
or HDD is bad
or the OS is corrupted.
what I do is boot to linux live cd/dvd or usb stick
if that works we know the HDD is the problem in 1min flat.
the we, hit f11 at power on and pick restore, and pick
the 2005 is us on the cusp of having F11 working or not
F11 is the key that has the full XP install on the HDD.
we run a linux (knoppix 7) DVD there and do the DISK test there.
if that fails the HDD is bad.
see it run here, this live DVD OS is the best test disk around.
and 100% free. if you can burn it or burn to USBSTICK mem.
http://www.pcdied.com/brick-dead.html#Knoppix
running knoppix tells me pc is ok
and at same time the HDD is good or bad.
if the F11 key works, then if lucky you can do repair restore.
or a start up file fix.
F11 runs the HP restore partitions,
id read you service Guide for you and look but HP deleted it.
Aug 08, 2017 | HP Computers & Internet
How to restore factory settings on the l-305
restar and as booting continuoasly hit f11 to do a restroe.
Your f key recovery depends on laptop model and type.
Usually tells you on boot up what key to hit for restore/recovery.
Apr 15, 2013 | Toshiba Satellite L305-S5921 Notebook
Power comes on no video, monitor works
Try hitting the F8 key or what ever is the key for safe mode, or try F11 for boot menu, if boot menu shows boot to hard drive.
If these don't work, unplug the PC, then hold the power button until the lights flash or hit again and make sure lights don't flash on.
remove the side cover, touch metal, then remove the little round battery for 5mins, replace, plug in, hit power, not hit the delete key and try to boot into the BIOS, you will need to set the date and time. then move to exit and save changes and exit.
Mar 14, 2013 | Dell OptiPlex GX620 PC Desktop
I forgot my passowrd and the labtop doesnt have a spot to use a cd. how can i unlock it ?
There is a key stroke at boot to rebuild the laptop. You will probably loose all your file though. hit tab or escape to see instruction of wich key. I think its f11 but not sure.
May 24, 2011 | Acer Aspire One PC Notebook
System recovery
F8 does that for you upon starting the computer up. Keep hitting that key upon starting till the screen shows up
Jul 28, 2010 | eMachines EL1200 PC Desktop
Windows could not start because the following file is missing or corrupt windows root>system 32 toskrnl. exe please re install a copy of the above file. I do not have a copy of the 2400 dimension dell...
Hi, Here is what you have to do. This is a common problem
What resources you need:
  • Windows XP Bootable CD with Recovery Console.
  • Basic knowledge of Dos Commands.
Steps:
  1. Restart your computer and go into BIOS. Use the key which will be shown during the booting process (Default keys are Del, F2, F1, Esc and F11)
  2. Set the Boot Order to boot from CD/DVD.
  3. Insert the Windows CD.
  4. Boot the machine.
  5. Press any key when you are prompted: " Press any key to Boot from CD"
  6. Let the components load. After loading you will be asked whether you want to Install or Repair.
  7. Press R to start the Recovery Console.
  8. Let the components load.
  9. You will be asked which Windows Installation you want to access. If you have only one Press 1. If you have more than one, use the number their. It will be shown.
  10. Enter the Administrator Password to continue (If you have prompted). If you have a blank password, just press Enter.
  11. Now you will be in C:\Windows\>
  12. Now you have to find the Drive Letter for your CD Rom which has the Windows CD in it.
  13. If you cannot remember:
  14. You have to check one by one to locate the I386 folder. Its in the Root of the Windows CD. Type this command and hit enter.
  15. Driveletter:
  16. Example: D:
  17. Hit enter. Now you are in D:\>
  18. Type this command and hit enter.
  19. dir
  20. Now you will see each and every directory (and file), Do this for each until you locate the Windows CD. It has a folder named I386.
  21. When yo are their, remember the Drive Letter.
  22. Go back to C:. Type this command and hit enter.
  23. C:
  24. Type this and hit enter again. Note the space between cd and \.
  25. cd \
  26. Now your are in C:\>
  27. Type this and hit enter.
  28. cd Windows
  29. Type this again and hit enter.
  30. cd System32
  31. Now you are in System32.
  32. Note: If you were restricted to access Windows folder you have to reboot and come back to the Recovery console again.
  33. Now type this command and hit enter. I am assuming your Drive Letter (CD\DVD ROM) as E:.
  34. copy E:\I386\ntoskrnl.exe
  35. Now you will be shown "One file copied". If so you have successfully completed the Recovery Procedure.
  36. Type Exit an hit enter.
  37. Now your machine will be booted properly.
Feel free to contact again if the problem persists. Please be kind enough to rate the answer as well!
Thanks for contacting Fixya!
Jul 12, 2010 | Microsoft Windows XP Home Edition
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
Jul 10, 2010 | Gateway MT3705 Notebook
Hi I have got a dell optiplex gx270 with the licence of win xp pro, I am trying to restore the system with ctrl F11 but nothing work, when I select boot from cd the system lunch win xp pro with login and...
if you want to restore the computer to the factory settings.
restart the comptuer. immediately hold down the CONTROL key and start tapping F11 key.
Note : all of the data and software would be lost. Your computer will be restored to factory settings like a newly brought system.
IF this does work then go to bios, and make cd rom as the first boot devices, hit f10. now, hit "escape" once and select, "save" and hit enter.
Now, comptuer will be restarted.Now,start tapping space bar, It will boot from the disk.
else restart the computer and again start tapping spacebar at the startup.
Dec 06, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
FN + F11 "turned on" at boot up
This feature is turned on and off in the system BIOS.
During startup, hit either the DEL or the F2 key to enter the setup.
Read through the items found there until you find the keyboard options.
good luck.
tony
May 11, 2009 | Acer Extensa 4620 Notebook
Acer daulcore processer motherboard model mcp61sm-am
ok fair enough.... boot the computer and watch the screen.... you need to watch for the key to enter setup.... delete key seems to be the most popular but i've had computers use f1 and f2, f11 and f12.... if it goes to fast hit pause as it gets to the point where it tells you the key to hit to enter setup.... after you are in change the boot sequence to boot to cdrom..... hit f10 and save the changes... reboot to the cd and continue with your install
Robert
Sep 03, 2008 | Computers & Internet
Gateway M360X Notebook Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
