Question about Epson Perfection 1670 Flatbed Scanner
Computer says there is no document on scanner
The scanner scans but after doing so, a message comes up saying there is no document on scanner. I have tried several different types of documents and get the same error message.
  • Anonymous Apr 13, 2009
    exact same problem
My scan doesnt work i've download de epson scan but still nothin i can c only a red light
Posted on Jul 20, 2009
I looked at whatsopuny said and went from there. I used windows search utility to look the file he suggested, didnt find it, and then did a search for *.ds. I found a file named per1670.ds in th epson folder -- which I figured was the same thing. I copied that and then saw a file located in the TWAIN_32 folder. I clicked on that, then on the toolbar clicked on file, then "open containing folder." When I got there, I went up one level to get to the TWAIN_32 folder and pasted in the per1670.ds file that I had copied. I didnt know if that would do it, but I restarted my computer, and it worked.
Posted on Feb 16, 2009
Had same problem with mac os 10.4 solution was downloading the latest epson driver from epson it still didn't work. turned out that the "epson perfection 1670.ds " old file was in the trash and the scanner was still using it. I turned off the scanner, rebooted the mac and "empty trash". Turned scanner back on and it worked. If you still have the problem make sure that you only have on "epson perfection 1670.ds" file in your HD,library,image capture,twain data sources.
Posted on Feb 11, 2009
  • 684 Answers
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Posted on Jan 26, 2009
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
May 01, 2011 | Canon Pixma MP480 All-In-One InkJet...
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
Scanner will not initialize
When I try to scan a picture a message comes up that says "A problem prevented the document from being scanned." What do I do?
Sep 16, 2009 | HP Scanjet 5500c Flatbed Scanner
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Sanner
TWAIN Driver and EPSON Scan Utility v3.04A
http://www.epson.com/
Hi, try this version just visit epson web site to download scanner driver.
Jan 13, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Perfection 1670 Flatbed Scanner Logo
850 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
