Question about HP Compaq Presario SR5610F Desktop PC
Heatsink how do i locate the heat sink
  • HP Master
  • 27,725 Answers
INSIDE A COMPUTER OR THE HEAT SINK FOR YOUR COMPAQ COMPUTER?
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer. Processors are very finely engineered components that are not repairable. But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer. Just check with HP/Compaq for the correct and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the cover. Lay the computer down flat. If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs. Examine the processor assembly. The processor is a square chip that is covered by a metal heat sink with fins. A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard. Two clips usually secure the heat sink assembly to the top of the processor. Gently press down and slightly away on the flat end of a clip to release it. Avoid using a screwdriver to release a clip; a slip could scratch the motherboard. Release the clips and gently remove the assembly. The heat sink should separate, leaving the processor behind in the chip holder. Clean the bottom of the heat sink. Use a paper towel and a dab of solvent cleaner to remove the old thermal paste. Set the clean heat sink aside. Lift up the lever to unlock the old processor and remove it from the pin mount. Insert the new processor chip. Align the pins on the processor to the "cut off corner" or dot on the pin mount. The processor should drop into the pin holes easily. If the processor won't drop in easily, check the pin alignment. Once the processor is inserted correctly, pull down the lever to lock in the chip. Apply thermal paste to the bottom of the heat sink. Apply enough paste to cover the area of the small gray rectangle on top of the processor. Apply the paste with a spreader made from a piece of flexible plastic. Spread the paste evenly to a thickness of two sheets of paper. Check the heat sink mounting alignment and lower the heat sink onto the top of the processor. Reinstall the mounting clips. Reattach the heat sink fan to the motherboard if necessary. Plug in the computer and monitor and boot. If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully. Shut down again and replace the exhaust fan hood. Close up the computer and reboot. Hope this helps.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=thermal+paste
Posted on Jan 19, 2013
Remove heatsink
There is usually 2 clips on heat sinks which can be accessed on the sides of the heat sink itself, you'll need to move the latches from the lock position to the unlock position.
If there aren't latches on the sides of the heat sink then it may use push clips that hold it to the motherboard, those can be accessed by removing the motherboard and squeezing the plastic clips together with a pair of needle nose plyers. The clips will be located on the underside of the motherboard.
Feb 07, 2012 | HP Pavilion Media Center m8530f...
Can you tell me where the 2 Convergence IC's and the 12, 6.8 ohm 1 watt resistors are located in the Magnovox 51MP329H TV
When you remove the rear cover you will see the large green board on the left side. Note the two large aluminum heatsinks with the fins? The 2 Convergence Ics STK392-120 are attached to that heat sink the 12 6.8 ohm resistors are at board location 3149-3160 they are all the 6.8 ohm 1watt metal film resistor located near the Heat sink which has the two ICs.
Aug 25, 2011 | Philips Magnavox 51MP392H Rear Projection...
Toshiba Satellite L500D is shutting down by itself OVERHEATING Clean the fan with compress Air ....> NO GO Need help Please or Any other Suggestion
Disassemble the laptop and remove the heatsink.
Remove all the dried up heatsink goo that's on the heatsink and processor.
Squeeze a small amount of QuickSilver heatsink compound onto the middle of the processor top.
Place the heatsink on the processor and move it in a couple small circles before locking the processor heatsink back in place.
Clean the air vents and cooling fins well while the unit is open.
This should fix any overheating issues you are having (assuming the fan is OK)
If the fan isn't running, replace it.
Jun 24, 2011 | Computers & Internet
Am using an mPAQ model:M66SE laptop. it heats up very much and after few minutes it hugs up.until i restart and wait few some minutes and cools. what will i do. the heat sink on top of the south bridge is...
remove your heat sink then clean the surface of the heat sink with clen cloth apply athin layer of heatsink compund and fix the heat sink tightly if the heatsink is dried or worn out the heatsink gets heated up also check the fan is working
Mar 28, 2011 | Compaq Heatsink CPU Heatsink & Fan
I need to know where the processor is located so it can be replaced
The CPU is located under the fan and heatsink assembly.
Mar 12, 2011 | HP Tablets & eReaders
System battery voltage low/chipset heat sink not detected, and where is this battery located along with the heatsink?
The battery is on the motherboard and looks like a watch battery...about the size of a nickel. The heat sink is the metal device underneath the fan on your CPU. See Pics Below...
Make sure your heatsink and fan are firmly connected to the motherboard.
Aug 10, 2010 | Dell Dimension 4600C PC Desktop
I am trying to find out what heatsink i have in my aspire x1300
my suggestion is remove the heat sink on your desktop. bring the heat sink as a sample then buy new heat sink.
May 16, 2010 | Acer Aspire X1301U9032 (PTSCM02007) PC...
HP stops giving input to mnitor, have to reboot whole system.
that is problem of processor when processor is overheated it do so there is a white heat sink compound between processor and heatsink detach heat sink and apply new heat sink compound on the processor and look properly that heatsink is firmly fixed to processor or not .it may problem of fan if fan is rotating with low frequency then also it happens replace new fan the frequency of fan can be seen in setup
Apr 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A processor...so do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
HP Compaq Presario SR5610F Desktop PC Logo
43 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
