Question about Hoover Dryers
My Hoover Vision HD tumble dryer keeps stopping after about 12-15 rotations and then all the lights start flashing
I have cleaned the filter, the water reservoir and the lint collector. I have reduced and increased the load. Still it keeps happening.
4 Suggested Answers
  • 3 Answers
SOURCE: hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Posted on Dec 14, 2008
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
SOURCE: Hi, My 8kg Hoover Tumble dryer Vision HD stopped
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Posted on Jan 11, 2011
I wash all my darks together. No fuzzy stuff either with the black items. Don't overload as I am only person doing laundry. Why the lint left on the clothes. Kenmore Elite Series 600. Please help.
Your Kenmore washer does not have a lint filter. Washers manufactured today and in the past few years are not designed with lint filters. The engineers rely on the dryer to remove any lint left on the clothes that doesn't get flushed down the drain.
overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely.
Lint can be trapped in the load if overloaded. Wash smaller loads.
Use the correct water level? The water level should be correct for the load size. Clothes should move freely in the water.
Alsp liquid detergent works better in cold water and has modifiers to keep lint in the water not on the cloths.
Do you line dry your clothing? If so, you can expect some lint on the clothing.
Check the following too
Was paper or tissue left in the pockets?
Use the proper cycle time for the load? Reducing wash time (duration) is another way to reduce lint.
these should help in reducing the amount of lint left on your clothes.
Thank the wonderful engineers for this problem.
There is one other thing you can do. Micro fiber cloths attract lint like nothing else. Inexpensive ones added to a wash load will catch almost all the lint.
found this out the hard way by trying to clean some that I used in auto body seminars for removing polish and waxes when doing detailing demos. they came out full of lint when washed in a mixed load,..looked worse than they did dirty. well sort of..they were still good for what i wanted them to do but looked like heck. :) if rewashed alone they cleaned up.
hope I helped a little.
Dec 31, 2017 | Kenmore Washing Machines
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
Dirt is laid down on my clothes that did not have it when i put them in
There is no filter in these machines.
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading Smart-drive or the dryer. Permanent Press or Delicate
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Sep 10, 2012 | Fisher and Paykel Washing Machines
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
9.2 Soiling
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3
Linting
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
9.5 Black Marks on Clothes
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
9.6 Grey Marks on Clothes
this is a problem it is recommended that the machine be periodically filled with hot water, plus
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator.
Jul 09, 2012 | Fisher and Paykel Washing Machines
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Hotpint Aquarius CTD00 Condenser Tumble Dryer, it has stopped drying the clothes. It occassionally works on the high setting (but makes my clothes smell a bit burned out and shrinking) but it...
it could be blocked up with lint, take out the condenser (silver fin bit) and clean run under a tap if necessary, this is the most important bit of the condenser if this is dirty it reduces the efficiency of the dryer. clean all filters with a vacuum cleaner even remove them and clean where they sit in the machine with the vacuum cleaner.
for the reservoir remove a check the inlet is clean and clear. look inside the machine where this is located and again clean and clear this area, then using something long and thin press open the valve that the reservoir mates with (this can often stick with lint and water residue) be-careful though when opened the valve will **** out water so have a few towels to catch it all. and finally raise the front feet a little this will help the water fall to the reservoir.
if this does not work the internal tank may have fluff and this would be a big job to get to this and clean it you have to strip the drum out which can be a pain.
Jul 22, 2009 | Hotpoint Dryers
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Dryers Logo
237 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
