Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a WD52528 and it turned off and the lamp light came on.
    Problem Solver:
  • 4 Answers
I had the same problem took it in and it was the bulb had over heated and blew out. The bulb is $199.00(here in wisconsin).After teh repair i called hitachi they told me i could have done it myself without having to take the tv in...Hope this helps.....
Posted on Jan 26, 2009
2000. Where is fuse for tail lights?
Do your headlamps work ?
Park/Marker/License/Tail Lamps
Voltage is applied to the turn/headlamp switch at all times. When the turn/headlamp switch is in the PARK or the HEAD position, voltage is applied to the following components:
The park lamps
The marker lamps
The tail lamps
The license lamp
The front marker lamps are grounded through the turn filament of the respective front park/turn lamp. The front marker lamps light as a result.
The automatic lamp control function turns on the park lamps and the headlamps. This action occurs when the ambient light sensor determines that the exterior lamps should be turned ON based on the amount of available light. When the BCM grounds the park lamp relay, voltage is supplied directly to the park lamps, bypassing the turn/headlamp switch assembly. When this action occurs, the following conditions exist:
The automatic lamp control relay is grounded.
The headlamps turn ON. Refer to Headlights/Daytime Running Lights (DRL) Circuit Description .
The lamps turn OFF when the BCM does not ground the park lamp relay or the automatic lamp control relay. This action is caused by the following conditions:
The available light reaches a predetermined level.
The ignition switch is turned to the OFF position
Mar 31, 2016 | Pontiac Grand Am Cars & Trucks
My mitsubishi model wd52528 was in storage for awhile and my inputs worked before I had to put it in storage i just recently replaced the lamp and I never had a remote for it but now my inputs won't work...
rear projection t.v's are very tempermentle although you reaplaced the lamps if its been in storage the slightest bang or bump can blow the lamps are they are very fragile check them again you might find you will have to replace them again either that of get a l.e.d tv there a better picture samsung full high devonition will have you glued to your tv.
May 04, 2014 | Televison & Video
I have a mitsubishi projection tv. I need to replace the bulb. Does any one know the difference between a pure glare bulb and a osram neolux bulb? Which bulb is right product for my tv? Also, which bulb is...
When in doubt check with sites such as www.TvRepairKits.com - check their online store first then email them if they do not show it. In most csases OSRAM is a great lamp...nore sure about pure glare...
Feb 22, 2013 | Philips 915P028010-P Projection TV...
Lamp turns on lamp light starts blinking then turns off
Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
Feb 23, 2012 | JVC HD-56FB97 HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have a mitsubishi wd52528 and i have a blinking timer light that keeps blinking and won't go out. and it's keeping me from turning on the t.v.
In this case it can indicate various things, I would recommend that you get your users manual, because depending of the color and how fast it's blinking, it;'s the issue you will have.
Aug 04, 2009 | Mitsubishi Televison & Video
My 52 inch WD52528 will not download the On Screen TVGuide listings. emoore8870@aol.com
Sounds like you are not using a cable/satellite box. If not...you can't get the TV guide listings with just a direct connect to the cable outlet or via antenna or equivalent.
Jul 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52528
That model has alot of issues with jamicon capacitors being bad. They are on every board of that model. I would suggest leaving it be, then if the problem gets worse. Then replace all jamicon capacitors at 1000uf on the entire chassis and your set will be fine. I would however suggest getting the service manual as they are involved getting apart, but a service center will charge an astronomical fee to service the set, and most do it at board replacement instead of component level repair. which is hundreds of dollars compared to a few dollars for new capacitors. Here is a link where you can get the proper afctory service manual if youd like one.
http://servicemanuals.vstore.ca/
Apr 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
