Question about Toshiba 36A50 36" TV
Toshiba 32" tv wont give sharp picture (other tv does)
Have toshiba 32" tv. When turn on, screen fuzzy (not sharp) looks likea tv that needs an antenna on it, to make the picture sharp. We have cable and our other tv works fine. Also has fuzzy horizontal lines moving up the tv. What causes that and can it be fixed?
  • 666 Answers
Try to replace filter capacitor from power supply and in horizontal section.
Posted on Mar 29, 2010
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Oct 16, 2017 | Toshiba CX36F84 TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV has fuzzy piture, all colors, but contrast is awful
I think you'd have to look at how much a comparable set would cost. I know that flat screen sets are coming down in price.
One thing you could try is to adjust the focus control although if it just went all of a sudden, then this may not help. There are two controls on the flyback transformer. Follow the thick red wire from the top of the picture tube down to the transformer that it's connected to on the circuit board. There will be two controls, the upper one being focus (marked with an "f" or the word focus). Try adjusting this while watching the picture. A mirror may be helpful. At the same time, be very careful what you touch in there, any metal part could have high voltage on it. As long as you are just touching plastic parts you should be ok. A good rule of thumb is to keep one hand behind your back as you work so as you don't inadvertantly ground yourself to the chassis while touching something with a high voltage on it.
If this scares you a little perhaps it's worth taking the set to a shop for an estimate.
Oct 08, 2008 | Toshiba 32AF42 32" TV
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Toshiba 36A50 36" TV Logo
273 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
