Question about Michael Kors Watches
The jeweler said two screws are stripped on the back of the watch and he cannot remove the back to replace the battery. How can we get the back off the watch?
  • 3422 Answers
SOURCE: Casio Wave Ceptor 2296 watch battery replacement
yes, what they said is right and will cost upto $30 and can only be fixed by them.The problem is not wid ur battery it is wid some other parts also inside it..
Since they are professional technicians for casio they charge that much.i suggest u to go for it..
Goodluck..
please don't forget to rate me as fixya..
Posted on Feb 02, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Phillipe Stark PH1079 watch - Can't get back off to replace bat
There is nothing wrong with your watch. The problem is in tools the jewellers are using for opening the watch.
Despite being under one roof, watchmaking and jewellery are completely different trades and are miles apart. Jewellers usually are equipped with very basic watch repair tools and the case openers are no exeption.
You have to find your nearest watch repair shop and ask for watchmaker, not jeweller. Any decent watchmaker will have the right tool to open your watch and replace the battery in a matter of minutes.
Do not forget to rate, please.
Posted on Jan 15, 2009
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Posted on Apr 23, 2009
How do you remove the back of my nautica watch to replace battery
Take your Nautica watch to a jeweler for a demonstration of how to remove the back. You might be able to persuade the jeweler to install a replacement battery.
Dec 13, 2017 | Nautica Watches
How to change battery on H3 Tactical HTTH3.15111 watch
  • Remove back
  • Find battery holder
  • Identify type
  • Obtain replacement
  • Remove old battery; install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery.
OROO
Nov 21, 2016 | Watches
Jia heng lighter watch parts and configuration of components?
Jia Heng Butane Lighter Watch Battery Replacement
The battery replacement for the Jia Heng Butane Lighter Watch is fairly easy. The clock face actually gets removed from the lighter body. The only tools you will need are jewelers Phillips and slotted screwdrivers; Phillips and slotted.
Remove band by compressing spring pin with slotted screwdriver by pushing in the pin. These are standard watch band pins.Remove back 4 screws to remove backThe clock face is help on by 2 screws removed from the open back, there are at the 11 and 4 o'clock orientation when looking at the back.The front will drop off.Remove the plastic alignment spacer.Replace the 377 button battery.Put it back together by reversing the process.
Attached pictures
Front
Back
Clock face screws
Plastic alignment spacer
Battery placement
Oct 02, 2016 | Watches
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Just to know to open up the back of this Lorus watch, to replace the cell ?
Watch backs open three ways, the first way is 1) by small screws you will see them and need to remove them carefully as not to strip the screw head, if there are no small screws the watch could have 2) a screw back, it will have indentations evenly spaced all the way around the back, if it is a screw back it has to go to a jeweler or watch repair for removal with a special tool. You must eliminated 1 and 2, then 3) would be a pop off back, you look around the edge of the back for one indentation along the back of the watch, use a pocketknife to gently pop the back loose. I hope this helps! thank you!
Sep 21, 2011 | Watches
I bought a DKNY watch for my girlfriend last Christmas and the battery finally died. I have taken it to 2 different jewelers to get a new battery in it and they have both told me that one of the screws...
Have you ried taking it back to the supplier? If it is still under warranty, then they should be willing to replace tha battery and if that is not possible they should replace it.
Dec 21, 2010 | DKNY 1009 Wrist Watch
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    How to change battery on a swatch skin watch
    1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
    2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
    3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
    4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
    5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
    6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
    7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
    8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
    9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
    10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
    OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
    Aug 14, 2010 | Swatch Skin SFK254 Watch
    How to replace a battery on a ebel watch?
    The most water resistant watches will have a screwed down case back and crown for maximum water resistance, both of which are backed by internal gaskets. These are the types this articlde will concentrate on. To change the battery in a water resistant watch you will need:
    • Adjustable case tool
    • Case holder ' + google_ads[0].line1 + '
      ' + google_ads[0].line2 + ' ' + google_ads[0].line3 + '
      ' + google_ads[0].visible_url + '' + ' Ads by Google'; } else if (google_ads.length > 1) { s += 'Ads by Google
      '; for(i = 0; i ' + google_ads[i].line1 + '
      ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
      ' + google_ads[i].visible_url + '
      '; } s += ''; } document.write(s); return; } google_ad_client = 'pub-8735055091446807'; google_ad_channel = '5953492595'; google_ad_output = 'js'; google_max_num_ads = '2'; google_ad_type = 'text_html'; //google_image_size = '468x55'; google_feedback = 'off'; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
    • Small screw driver
    • Polishing cloth
    • Cotton gloves
    • Small tweezers
    • Plastic tweezers
    • Soft clean cloths
    • Battery tester
    • Paper cup
    Aug 10, 2010 | Ebel Sportwave Gent 100m Water Resistant...
    How do i remove the back on my sekonda mens watch
    mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
    Jul 12, 2010 | Watches
    Watches Logo
    333 people viewed this question
    Top Michael Kors Watches Experts
    Ansel Alberto
    Ansel Alberto
    ray gallant
    Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
