Question about FUJIFILM FinePix AX200 Digital Camera
Purple screen when switched on before focusing
    Genius:
  • 1,019 Answers
Hi Pat, Have this little checked to see if it needs service.
Posted on Jan 26, 2013
  • Patrick Brown Jan 26, 2013
    Any idea of the cause?
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
LCD screen turns purple in shooting mode. Photos can be taken. Most are Ok, some slightly out of focus or faded coloration. If switched to play back mode and then back top shooting mode, display is Ok for...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Apr 17, 2010 | Canon PowerShot S410 / IXUS 430 Digital...
My c180 shots turn purple while focusing or
I am guessing here that you are talking about the results in the LCD screen, how do the pictures look when downloaded to the computer.
Apr 04, 2010 | Kodak EasyShare C180 Digital Camera
The images displayed are purple. I sometimes solved the problem by adjusting the focus. Now it remains purple all othe time.
Hello...The problem you're describing is related to the green lcd and most likely the main board(green channel). If the focusing removes the purple(you have *that* much dust in the unit?) then it *is* dust. You should be able to focus on the dust particles twice--dust on the front of the lcd and dust stuck to the back of it. I'm gonna give you the color table so you know what to look for and what you're seeing. Red LCD=cyan(baby blue) onscreen; Green LCD=violet(purple) onscreen; Blue LCD=yellow onscreen
If you have a lot of dust(and the green lcd usually is the main culprit by the design of the lcd panels around a glass "cube" internally) you might try blowing some air into the unit when it's cool. However, the unit probably needs a good cleaning--remember to clean the dust filter! To properly clean the unit, a trained tech will have to perform the job. The lcd panels are DELICATE and precisely positioned for displaying a sharp image.
Sep 18, 2009 | Dukane ImagePro 8755A Multimedia Projector
No picture for Canon SD100 Powershot
See this link. This Canon service notice is effective world wide, and if Canon determines that your problem is due to a CCD image sensor failure (yours are the classic symptoms), they will repair your camera at no cost, regardless of warranty status.
Dec 10, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Sonykp-65ws510 convergence problem
Go to front of TV remove front bottom there you will find the focus and screen Block it has 3 on top and 3 on bottom This is to adjust screen drives and focus for each Tube R/G/B. also in front of ICs check your pico fuses they will look like resistors will be Green or yellow make sure they are good if opened they can cause your problem as well.
Nov 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi 53SDX89BA Projection TV
CRT lenses need to be aligned. Would recommend having a profesional technician do it. Easy fix for a CRT profesional but quite technical for the homeowner. Before fixing it, unplug. open up back go in and look at the front of the tubes with a bright flash light. If you see a brown square under the lenses you might just want to upgrade instead of fix. Brown square is CRT burn.
Oct 27, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Won't Focus!
No Fix - New camera time Do contact Canon Tech support, But I feel this is a firmware problem and there is not a fix.
Jun 23, 2007 | Canon PowerShot A70 Digital Camera
FUJIFILM FinePix AX200 Digital Camera Logo
19 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
