My printer hp deskjet 1000 j100A is in error state
Doesn>t print, always says" it's in error state"
IB4G2008
  • 3587 Answers
SOURCE: HP Deskjet 3820 states system error
try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
Posted on Mar 07, 2008
MRUTYU
  • 247 Answers
SOURCE: My Hp 3550 colourInk Deskjet is confronting an
remove data cable put it into another then try
Posted on Jun 26, 2010
Rider On Way
  • 1679 Answers
SOURCE: HP Deskjet 9800--when i try
Disconnect the power cord from back of printer ( printer must be powered on ) and wait for 30 secs. Connect it back.
Try to print. If it still does not print, click on the link below and follow the instructions to resolve your issue.
Clear Print Job Stuck in Queue
Regards,
Ron
* Rate this solution with Thumbs up and comment to help us improve providing support
Posted on Jun 12, 2011
  • 140 Answers
SOURCE: HP Deskjet 1000...will not work.
HI welcome to Fix Ya.
It sounds like the print spooling service in Windows is not running. This is easy to remedy. The first thing you need to do is start the service. The easiest way to do this is:
1. Go to Start and type "cmd" in the search box. This will bring up the cmd program (command prompt or DOS prompt). Right click on it and select "Run as Administrator."
2. This will bring up the Command Prompt window where you will see : C:/Windows/ system 32> "type" net (hit spacebar) start (hit spacebar) spooler (hit enter key)
3. Underneath the command you just typed, you will see the words:
"The Print Spooler Service is starting..............."
" The Print Spooler Service started successfully."
4. At the command prompt, "type" the word, exit. Then hit the enter key. This will close the program. So, it will look like this:
C:/Windows/ system 32>exit
Once you start the print spooler service, turn your printer on. Then, go to your printer's properties in Windows by going to :
1. Start> Devices and Printers>Click on it to open the window.
2. Select your default printer>right click on it and select printer properties.
3. After the printer properties window opens, click on print test page.
This should resolve the problem. Should you need further assistance, leave a comment below and I will be more than happy to assist you further. Thanks for using Fix Ya.
Posted on Jul 11, 2011
  • 199 Answers
SOURCE: my printer hp deskjet ink
it is problem with he paper pick up assembly unit.
Posted on Aug 05, 2011
HPD4260 unable to check ink levels via printer services
There are 2 ways to fix this.
First one is simple, While the printer is powered on, Disconnect the power cord from the back of printer and wait for 30 seconds and reconnect. You should find the ink level shown when you print.
Second step is is Uninstall the software from software disk re-install again.
Apart from these 2, there is no alternate way to check ink level on Deskjet printers
Regards,
Suhail
May 15, 2012 | HP Deskjet D4260 Printer
I have an HP Deskjet F2480 printer and since I installed the HP solution center, I keep getting the error message 'cartridge problem' and there are lights that are blinking on the printer which...
Go to Control panel > Printer and device (win7) or Printers and faxes (win xp)
right click on your printer > properties > Device setting
locate Installable Option to Black ( seems to me your colour cartridge empty or has been refilled)
apply > ok.
Next Go to control panel > add/remove program > locate HP solution center > uninstall
akee.4shared.com
Aug 15, 2011 | HP Officejet 4315 All-in-One Printer
My hp deskjet ink adv2060 K110 not print the spooler service not running?
Hello there Marejen,
See if there is any spooler.exe running in your task manager. Press ctrl, alt + delete to go there. If you see the process, click to highlight then end it. Then restart your computer and the printer itself. Then try to initiate a print again once everything is loaded.
Please let me know if this helps. Thank you for using FixYa.
Aug 02, 2011 | HP Deskjet 2460 InkJet Printer
Please send me my printer manual hp deskjet 1000 j100a
Please click th link below to download the manual you need.
LINK
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
Jun 19, 2011 | Office Equipment & Supplies
171 people viewed this question
jasbo
jasbo
