Question about Zenith D56W25 56" Rear Projection Television
Will not turn on
I got the tv gave to me and the only thing that was wrong with it at that time was the focus on it. when i got home with it and plugged it up and it came on then made this buzz sound and turned off what am i looking at and how much will it take to fix it
  • kstephens876 Jan 26, 2009
    what could i look for to tell which borad it is and where could i get it
    thank you do you think it is worth it if that is the only thing wrong with it is the focus and a board. all together on parts what am i looking at the tv was made in october 01 would it be worth putting it in
    Genius:
  • 2,920 Answers
300 to 400 dollars...one of the boards is shorting out
Posted on Jan 26, 2009
  • Ronnie Houston Jan 26, 2009
    you would be better off calling a tv repairman out and having them fix it.it could be in any of the boards and if you think the tv is worth about 300.00 working then id make the call. there are too many ifs on which board caused the problem
    probably 3 to 4 hundred tops..
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
Hey i bought a 05 focus on monday, they said it was fully serviced. this evening on my way home the engine light started flashing amber and loosing power. when i got home the light just stayed on then......
It could be many things. You need to have it scanned. Unfortunately, there are many things that can go wrong that a regular service will not repair. A scan will tell you what is wrong instantly and is the least expensive place to start.
Feb 17, 2011 | 2006 Ford Focus
Flyback shorted, trying to replace
astimagnetic.com:flybacks.video heads,laser pickup and more...
Jul 08, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
as i've read you statement your tv need to check parts by parts, the one you mention upside trace vertical line, that part control on vertical ckt faulty parts nearly to faded filter capacitor you can directly replace all capacitor of vertical section. the one you adjust is that the playback transformer the upper portion is focus and the lower portion is screen voltage controlling screen voltage supply to crt g2 pin. if you turn this high that resulting hazing sound come from 2nd anode cup.
Mar 29, 2009 | Toshiba 32D46 32" TV
Olympus FE-230 Digital problem
Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
Jul 27, 2008 | Olympus FE-230 Digital Camera
Surround sound and TV sound
Not by just pressing a button the Home Theatre no , I have the same problem on my Panasonic system - and I just mute the TV.
Mar 28, 2008 | JVC GL-M2915SG, Short Focus Manual Shift...
Blue Halo Across screen
Hello Damianian, I too have this hdtv and had problems with the convergance and self-focus within the first year of ownership. I called Samsung within the waranty period and they sent out a tech who replaced the convergance board for free and did the manual convergance in my home. After this, with the new upgraded convergance board installed, the self-focus was not necessary anymore so I turned it off. Some time later the convergance needed done again so I called to get a price on them coming out again to do it. I didn't like the quote they gave me over the phone (around $200.00usd) so I looked for a Service Manual online and found one on an Ebay store for a total of $13.00usd including shipping. I now perform the manual convergence on this set myself and it's easy to do.
Anyone wanting to get a Service Manual for their hdtv or other technical device should check these guy's out. They now have their own website. http://www.thecdguyz.com/
I hope this helps, good luck!
Dec 12, 2007 | Samsung HC-P4752W 47" Rear Projection...
Focus
Your problem could be caused by one of several things. The lens may be out of adjustment or have a loose mount. The camera also had problems with the mirror hinges. Look into the mirror area with the lens off to see if the mirror is square within the mount ring.
Oct 09, 2007 | Nikon N2000 35mm SLR Camera
Mitsubishi Big screen
This problem could be as simple as dirt or dust inside on the lens of the picture tubes or on the mirrors inside the projection tv. It could also be the blue tube is on its way out or the focus on the blue tube needs alighnment . This set has extremly high voltage inside, so its not for the do-it your selfer to mess with!! Now theres nothing wrong with a do-it your selfer but in this case save a life, and call a tech in to see if it just needs cleaning or light alighnment. If you call one, watch how they take apart the screen assy. from the tv and see how they clean the set ,so you can do it next time. Now like I said it could be a picture tube going bad too so please dont be too disapointed when they tell ya that. But depending on how old the set is ?? It might be worth investing in the set?? Also another thing , when the tech comes in they MAY say the set needs to go to the shop to be looked at . This is a way to get more cash out of ya as Ive seen simple cleaning or adjustment repairs turn into 500 to 700 bucks when in reality, it could have been done in the home for a hundred or so. Dont be afraid to pay someone a hundred or two, if they fix a broken set in the home, as believe me you saved a bundle when you let them, cause when it goes out the door (the set) tack on an extra 200 at least. Good luck
Jun 05, 2006 | Mitsubishi WT-42315 42" TV
Zenith D56W25 56" Rear Projection Television Logo
66 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
