Question about Microwave Ovens
Why does my microwave create condensation on door and interior
When using microwave, door and interior steams up creating condensation. What is wrong
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Accesive steam coming out from the door?
The stirrer and fan must be working properly.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find it, download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number (as RFS12SW2) from the tag on the oven here.
If you need it, we have uploaded the service manual here to our site to help you.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
  • 11 Answers
SOURCE: condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Posted on Aug 11, 2009
SOURCE: microwave sparks on the inside
It sounds like it needs professional servicing. There may be an issue with excessive radiation escaping from the oven -- this could be dangerous. Can't say for sure, but were it my oven, I would take it to a shop with the equipment to test for this condition.
Charlie
Posted on Aug 23, 2009
bozcro
  • 867 Answers
SOURCE: my whirlpool microwave model GH5184XPS4 has
un-plug it, it is not safe. i am thinking that the transformer is making the noise, probably because of the moisture.(cheap asian electronics) it could catch on fire.
Posted on Jan 14, 2010
Is my 2yr.old panasonic microwave that is peeling and chipping inside a manufacturing defect?
Not a manufacturing defect at all.
It is caused by customer error.
Keep the microwave cavity clean at all times and allow the condensed steam to escape by leaving the door open after use for a while.
Sep 18, 2017 | Panasonic Microwave Ovens
Microwave Cavity Paint
I would let it dry for a good 24 hours, if you still have a problem with smell use a mixure of water and vinegar in a small container, set for 60 seconds and run microwave when until it steams, it will bond to the interior wall creating a barrier.
May 17, 2012 | Microwave Ovens
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
There is steam inside the microwave when my food is heating up. Is this dangerous?
If the steam is not leaking out of the microwave it is no problem. Steam is normal when you heat moist items. If it is leaking out you need to replace the door seal, but steam will not start a fire.
Feb 16, 2012 | GE Microwave Ovens
MICRO WAVE DOOR FOGS UP WHEN USING IS THAT NORMAL
A Microwave Oven works by heating water/moisture in food: if the boiling action (e.g. when boiling water) is greater than the oven exhaust fan can cope with, then the inside will steam up and fog the door glass: this is usually OK and 'normal' (this is actual the advise in cleaning up the interior of a microwave oven - steamy soapy water - see your manual).
Hope it helps.
May 16, 2011 | Hamilton Beach Microwave Ovens
Leaking water from the back
I can only presume this is NOT a microwave oven.
If it is, it will be condensation, so needs to be wiped up. Leave the door open after use for steam to evaporate.
This will be less of a problem if the room is warmer.
Dec 25, 2010 | Microwave Ovens
Condensation inbetween glass door on GE Spacemaker
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hole in film on interior door
wouldnt be concerned about hole in the film strictly cosmetic!film wouldnt be available youd need t repalce door and thats just not feasable
Mar 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
279 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
