Question about Acer Aspire 5100 Notebook
My Laptop is suddenly taking 15 minutes to load up after turning
Everything is really slow. The media player can no longer play a song without skipping and other software seems to have trouble running. The internet is also having trouble surfing the web.
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Follow the tips below to boost your system.
  • Scan Laptop for Viruses
  • Fix Registry Errors
  • Run Check Disk
  • Stop Unnecessary Background Programs
  • Run Disk Cleanup
Laptop runs slow issue may appear if the system is infected by some malicious application. You have to search and remove that application from your system. For your convenience download and install a powerful antivirus program. Run a complete PC scan to detect viruses and remove them from your system.
Note: Close all other programs before start scanning your system.
Run Check Disk
Errors in the operating system may result in laptop runs slow problem. To remove errors you need to run check disk. To do so follow the steps below:
  1. Open My Computer
  2. Right Click on (C:)
  3. Go to Properties
  4. Click on Tools tab
  5. Click on Check Now under Error-Checking
  6. Click on Start
  7. Click on Yes for scheduling Disk Check on restarting your laptop
  8. Restart your computer
  9. Disk Check will automatically start when you logon Windows
Sometimes there are some background programs that are running without our consent and eating up the memory and energy of the CPU. Closing down these programs will speed up your laptop performance. To do so follow the instructions below:
  1. Hold Windows+R button on your keyboard
  2. Type msconfig and press Enter
  3. Click on Startup tab
  4. Click on Disable All
  5. Restart your Computer
Run Disk Cleanup
Efficiency of laptop decreases when it contains too many junk files. To clean junk content from your system follow the steps below:
  1. Click Start
  2. Type Disk Cleanup
  3. Press Enter
  4. Select the drive which you wish to clean
  5. Click OK
Fix Registry Errors
Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable Registry Cleaner tool click here.
Posted on Jul 08, 2011
  • 56 Answers
Try downloading CCleaner and Lavasoft Ad-Aware these are both free and both do different things for cleaning-up registry, unwanted cookies and adware issuses. go to accesories then system tools , defrag and disk clean-up. GOOD LUCK
Posted on Jan 26, 2009
  • Acer Master
  • 4,806 Answers
Clean the pc up to speed it up a little, download ccleaner and install it, run the cleaner and delete all the files it finds, then clean the registry and fix the issues found, if it asks you to save the changes to the registry click yes and fix do this a couple of times so no issues are found.
If the pc is still slow after this clean then the issue is either memory or the operating system is degrading.
http://www.filehippo.com/download_ccleaner/
good luck
When i downloaded songs on my rca mp3 player it freezes
@ _ @ thats just it you can't turn on the thing to delete them, even your computer won't do it. FAIL....
Jun 03, 2010 | RCA M4304 Digital Media Player
Limewire 5.0 sucks!
There are several things that I can see that might be driving your mp3 player haywire:
A) About 1/3 of Limewire songs contained some type of writing in the "Comments" section of the songs' ID3 Tags before version 5 - it may be up to 100% now, and your player obviously doesn't like it. This is going to be a real bear, but I would take one of the songs you just downloaded, open it in Windows Media Player, and right-click the song title within Windows Media Player. Select "Advanced Tag Editor," and delete any writing that appears in the "Comments" section of the ID3 tag. Then try transferring that song to your player and see if it plays correctly. If it does, repeat with all of the songs you just downloaded. It will take you forever.
B) If you use iTunes to transfer songs to your mp3 player, version 5 will not work with iTunes - it simply pastes a data file into iTunes which is not the actual song, so it may appear to transfer correctly, but in fact you have not transferred the actual song file. Use Windows Media Player to transfer instead.
C) The bitrate on songs in version 5 is higher - most mp3 players have a maximum bit rate that they can handle, and ver. 5 might exceed this upper limit. The solution would be to convert all of your mp3 files to a lower bit rate using free software such as Media Monkey.
Without dragging this explanation out any longer, I think your best solution would be to revert back to Ver. 4.1 or so.
-Tha Mp3 Doctor
Mar 31, 2009 | Nextar MA933A MP3 Player
My Laptop suddenly takes 15 minutes to turn on from the loading screening (where it says acer after its turned on and the blue loading bar is going) and simple tasks are now slower, such as the media...
The best thing you can do is add more RAM. As more programs and documents are loaded the more RAM it needs. However, there are also a couple of other things you can try first. This will clean up all the old /tmp files that are not needed and also fix your hard drive so all the data is together and not spread out.
click on start>programs>accessories>system tools>disk cleanup. Run this first to get rid of the junk files that are left on your computer by websites
After the disk cleanup go back to the same location and run Defrag.
Each time you delete a file it leaves a blank space on the hard drive. after a while it takes longer to find files. The defrag will push all the data together in a row so it is faster to find.
Hope this helps.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
WILL NOT PLAY
This player will be ruined by using Windows Media Player 11 to transfer songs. It may work fine for a while, but eventually it will fail. You already ran the Repair and it didn't solve the issue, so if it is a Windows Media Player-related issue, that player may be toast.
Alternatively, you may be trying to load a song that had a fixed-term DRM license. The license could now be expired, requiring you to refresh the download through the music service from which it was purchased.
-Tha Mp3 Doctor
Dec 01, 2008 | Philips HDD1630 MP3 Player
Frozen Completely
Press and hold the 'user' button with the play/on/off button. This should reset the player.
Aug 25, 2008 | Samsung YP-U3 MP3 Player
SSLlllllllllllllooooooooowwwwwwwww
Make sure the songs are in the correct format
Aug 13, 2008 | Nextar MA933A MP3 Player
Wont turn on
Walmart is still selling an iLO brand player that has an SD slot.
http://www.walmart.com/catalog/product.do?product_id=4127960#Specifications
May 01, 2008 | iLO (2 GB) MP3 Player
No brand mp3/mp4 player
download songs from computer to mp3/4 player
Dec 11, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk e250 mp3 player froze up and won't turn off!
To Reboot your sansa e250 without removing batteries . Switch to hold position ( right beside headphone jack ) Press and hold menu and rec buttons at the same time untill screen resets. On my player lock up usually happens when it hits a corrupt song - try to delete and reload the culprit to minimize future lock ups. Hope this helps someone out there.
Nov 15, 2006 | SanDisk Sansa e250 MP3 Player
Acer Aspire 5100 Notebook Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
