pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. ************************
Hope this helps :)
Comments:
Jul 20, 2007
- Did you find the section describing how to install/remove the toe panel and the door fascia panel? They are on pages 16 and 11 of the pdf file.
If you still have problems finding the info please let me know.
Rating Locked! (?) cleberg has rated this solution as Not Helpful
The detergent dispenser for the Bosch SHV46C does not open during cycle and none of the detergent is...
(More)
The detergent dispenser for the Bosch SHV46C does not open during cycle and none of the detergent is used
detergent dispenser won't open during wash cycle I took it off and the spring seems to have ony one...
(More)
detergent dispenser won't open during wash cycle I took it off and the spring seems to have ony one conection point. How do I reinstall it so it will trigger properly.
hello
my bosch started leaking h20 fr4om bottom then it ran all night and now when you push start...
(More)
hello
my bosch started leaking h20 fr4om bottom then it ran all night and now when you push start button when door open you can hear motor run...
