Question about Philips 32PF5531D 32 in. LCD Television
How to tune bbc on 32pf5531d/10 after digital switchover
Since the digital switchover I have been unable to tune bbc1 and bbc2
2 Suggested Answers
SOURCE: My Philips hdt8520 has lost
This happened to us. we reset the box to factory settings and all channels came back. hope this helps
Posted on Apr 14, 2011
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Can get bbc picture but not the other channels
BBC1 and BBC2 are among the strongest signals you could simply have a low signal reception, try a channel dump and re scan for all digital signals, try re tuning on a different aerial if that's possible. If all this proves fruitless the fault will most likely be on the Main AV Panel where the tuner an IF stages are found. Post your Brand and Model Number for more specific help suggestions
Dec 30, 2015 | Televison & Video
Lost BBC1 BBC2 digital after switchover
You might have more than one transmitter. Some TV's etc only store a certain number of channels and have a max amount!. When weaker transmitters are present sometimes the memory of the TV will only store the stronger signals first from these weaker sites, with the two BBC channels being too weak to be detected.
The solution is to do a manual search on the transmitters you know are very strong. For example if channel 43 has strong signal you would search on that. The auto search will start at 21 and work it's way to 69. But if your area transmitter with the strongest signals is high up the scale the weaker transmitters will be selected first!
Apr 09, 2012 | Electronics - Others
Panasonic lcd tv model no. tx-26lmd70. since switchover day 6/4/11 i have not been able to receive bbc1, bbc2, bbc3 channels auto tuned 3 times a day to no avail. panasonic helpline is jammed with other...
This This is a difficult one . You may have to go online to get an Upgrade for the TV..You will need a flash drive and of course there must be a USB socket on your tv... Other than that im stumped. Sorry.
hope this helps
Apr 08, 2011 | Panasonic Televison & Video
Can't get BBC1 or2 since the switchover with Durabrand DPVR801
So you think I'm gonna answer my own question then tell you how I did it, so that you can then CHARGE someone else for MY answer?! I don't think so! An excellent 'service' you have here - I DON'T think.
Nov 11, 2009 | Televison & Video
Used new codes but have no bbc1 or bbc2 but have all others
try re scanning your channels, happening a bit at moment because of switch from analogue for bbc etc
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ferguson DV3 set-top box not finding BBC channels
I have solved the problem by selecting Manual Tune in the Menu. This means selecting each channel one at a time beginning at 21. The indicator shows the Signal Strength and Quality for each channel. If both show a green bar (strong on both counts) give it time to identify the new programs on each channel and add them. It will show how many found and added if you wait a few minutes. When each channel is done, move on to the next one. The last channel is 65 I believe but there is not much up the top end.
When I had finished going through this routine I found it had indeed added all channels I needed including BBC1 and BBC2
Aug 21, 2009 | Televison & Video
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
Philips 32PF5531D 32 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
