Question about Gateway Computers & Internet
Sound starts and stops while watching any video clips from any site
I have a Gateway NV52 Laptop . When veiwing You tube or any other video clips from any site its as if the people are stuttering . you cant hear what they are saying because the sound cuts in and out
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Its a browser problem... try installing a different one or updating your browser and its plugins... :)
Posted on Jan 19, 2013
  • 691 Answers
SOURCE: nv52 sound card drivers for XP does not work
This problem is listed under MT3705 notebook, which doesnt use NV52 drivers but sigmatel
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014142R
If all else fails remove the drivers restart PC and get windows update to try and solve it.
Posted on Aug 02, 2009
SOURCE: GATEWAY NV52 LIVE VIDEO CAM ?
type camera in the search under the start menu and you will see a little camera if u have the nv52.. just click it and it will start your cam
Posted on Sep 24, 2009
SOURCE: No Sound Webcam or Bluetooth Gateway NV52
the conexant audio drivers are for windows xp 32-bit only. if you installed xp 64-bit you are screwed....
there are no sound drivers for the 64bit version of xp..
only the ATI Hi-def HDMI output audio drivers will work...
Good luck
Posted on Nov 05, 2009
bob_computer
  • 3153 Answers
SOURCE: Gateway NV52 Blank/Blue Screen after 20 minutes of use
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Posted on Nov 27, 2009
SOURCE: Gateway NV52 Laptop charger sound.
I don't know if this will work with Vista but in Windows 7 you can go to the speaker icon in the taskbar and click on the icon above the volume control. This will take you to the sound properties. Click the levels tab and mute the PC speaker. This worked for me.
Posted on Jan 30, 2010
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
Ggateway ms2274 shutting down wont start up
onehugo, has the inside of the laptop been cleaned out?
The Gateway MS2274, is also known as part of the Gateway NV52 series of Notebook PC's.
Look on the bottom of the laptop, and post the Model Number.
(Examples, NV5207U, NV5211U, NV5212U, and so on)
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/nv52/NV52nv.shtml
(Clicking on Product Views, then on the different product views given, will show you the ms2274 is part of the NV52 series )
The laptop uses the same cooling system as most laptops.
1) Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
At one end of the Cooling Tube there are two small metal plates. One plate sits on top of the Processor. The other plate sits on top of the graphics chipset.
At the other end of the Cooling Tube a Heatsink is mounted.
2) Heatsink:
For this series it is a rectangular finned object. Small strip of metal with Tall, Thin fins protruding from it.
3) Fan Assembly:
Fan set inside a backwards D shaped shroud. (Surrounding cage)
The Fan Assembly draws air up from the bottom, then exhausts the heated air out of the side of the laptop.
Operation:
The two small metal plates absorb heat from the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat along it, up to the Heatsink
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
This is an up close example of the cooling system used, on the Gateway NV52 series of Notebook PC's,
http://www.laptopneeds.com/parts/show/120817549354/
Scroll the page down to the photos.
The bottom photo shows the cooling system, as it looks removed from the laptop, and the side that contacts the Processor, and graphics chipset.
Here I am able to show you the metal plate surface, that contacts the Processor, and graphics chipset.
With this design there is only one large metal plate to do both jobs, instead of two small separate metal plates.
Coming from the end of the copper Cooling Tube, and going to the Left;
1) You will see a small square, covered partway with a gray Thermal Paste.
(Thermal Paste makes a triangle shape)
This pad sits on top of the Processor/
2) Coming to the left a little further you will see a rectangular copper pad, with gray Thermal Paste smeared on it. This pad sits on top of the graphics chipset.
[ The Processor and graphics chipset, are the two hardware components inside a computer, that give off the most heat ]
Also here you will see at the side of the (Black) Fan Assemblies shroud, is the finned Heatsink.
Point of this long 'dissertation'?
Want you to see the cooling system, and especially the fins of the Heatsink.
Air is drawn up by that fan, and pushed through the fins of the Heatsink.
ANYTHING the fan draws up with the air, is pushed through the fins of the Heatsink
Dust, dirt, hair, food crumbs, lint, ...you name it, is drawn in.
This coats the fan blades, fan's center hub, and surrounding cage. (Shroud)
Also clogs the fins of the Heatsink.
This drops the cooling capacity of the cooling system, tremendously.
The Processor, and graphics chipset overheats.
When a Processor overheats it turns off. (BIOS turns it off)
No Processor operating, no computer.
After a few times of this error codes are logged in. BIOS won't turn the Processor on, until the problem is fixed, and error codes are cleared.
Solution is to clean the inside of the laptop out.
Laptop partially disassembled;
Use an ESD wrist strap, ($3 to $6), and connect it's alligator clip to a good ground source.
Use compressed air for computers, a soft small brush, (Makeup brush?). and Q-tips.
No sir/ma'am.
Using compressed air at the Fan Assemblies opening, at the bottom of the laptop, (Air Intake Duct) WILL NOT DO THE JOB CORRECTLY.
It will just shove the gunk further into the fins of the Heatsink.
Use compressed air at the side of the laptop, and the exhaust port?
Even WORSE!
Also;
You see I mentioned Thermal Paste.
The bottom of the two pads on the large metal plate, on the Cooling Tube, (Whew!), is not perfectly smooth.
Neither is the top of the Processor, and graphics chipset.
A magnified view would show imperfections.
'Pitholes, Valleys, and Hills'.
When the two surfaces are mated together, (Pads on top of Processor, and graphics chipset), they create Air Pockets.
Air is an Insulator. Not a Conductor.
Thermal paste fills these imperfections, and is an excellent Conductor of heat. Transfers the heat well.
After time the Thermal Paste dries up. Caused by age, and the heat of the Processor, and graphics chipset.
Fresh, new Thermal Paste should be used.
The top of the Processor, and graphics chipset, plus the bottom of those two pads on the metal plates, should be cleaned THOROUGHLY!
Then fresh, new thermal paste is PROPERLY applied.
Software problem? Windows is messing up?
NO
You stated the laptop is shutting off, BEFORE the operating system is started.
[ You press the Power On button. This is tun presses against a momentary contact switch. The Power On switch.
The first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the O/S.
The Processor isn't turning on, or isn't staying on ]
I can post links to the NV53 series of Notebook PC's, for a Service Manual, and pictorial guide, for disassembly.
With this info you can crossover easily to your NV52 series.
If you wish to clean out the inside of your laptop yourself.
There is ALSO other needed information I will state along with them.
Post back in a Comment.
Regards,
joecoolvette
(Apologizes for the long solution )
May 17, 2012 | Gateway Computers & Internet
How to retrieve files from a hardrive on laptop that will not work
One way to do it would be first remove the hard drive:
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52faq4.shtml
Then use a hard drive dock such as this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071) to connect via USB to a working computer where you'll be able to access your files.
Jan 13, 2012 | Computers & Internet
Cant veiw video on you tube why? I am able to see
Have you downloaded Abode Flash 10.3? Go to the android market and type in abode flash install and you should be good
Jul 10, 2011 | Archos ARNOVA 10 Android Tablet
I wanted to know what I can do to fix the video problem I am having with my p-7805u FX. I have constant video driver failures and crashes when ever I veiw media. The screen tears and the system locks up...
You didn't mention what it is but I'm assuming you are talking about a Gateway laptop. It sounds like overheating problem of the graphics card. 2 reasons would normally dirt and dust in the heat sink and fan and the second reason a faulty graphics card. I would first get an air blower and dust off the air vent see if any dust comes out. Try to also place the laptop on an open surface not a carpet or sofa which may block the laptop air ways.
Oct 24, 2017 | Gateway P-7807u Notebook
Oct 14, 2009 | Gateway Computers & Internet
Aug 15, 2009 | Gateway MT3705 Notebook
Nv52 sound card drivers for XP does not work
Aug 02, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
