Question about GE WBXR2090B Top Load Washer
Washer tub has water but it will not drain
I have replaced the pump and cleaned out the hoses but there is still water in the outer tub. How do I get the water out?
    Sergeant:
  • 291 Answers
If you are refering to the sloshing sound when tub is moved back and forth it is supposed to be there. That is the balance ring. It is a liquid filled ring at the top of the tub that acts as a counter weight to keep tub balanced.
Posted on Jan 19, 2013
SOURCE: GE Mod WDSR2080D5WW won't drain
Thank you!
Posted on Feb 06, 2009
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
JULIANFIX
  • 975 Answers
SOURCE: clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Posted on Apr 16, 2008
SOURCE: ge washer not draining or spinning
Washer will not drain or spin. Got the water out andf tried it . It would spin and seem to drain what little was left in the drum. When I added about 1" of water it would not drian or spin. Drum sets at an angle also.
Posted on Oct 29, 2008
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WFL 2066 NOT DRAINING FULLY - NO SPIN
try to dismantle pump and reposition it and clean dirts that have accumulated on it that prevents water to fully drain. best i got
May 20, 2008 | Bosch WFL 2063 Front Load Washer
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Water won't drain , it spins but won't drain water
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting Fixya.com
Oct 09, 2009 | Hotpoint Washing Machines
I have a frigidaire affiniy front load washer. After I washed a lightweight blanket i heard a laoud noise from the machine and water was below the drum not behind from the hose. The next time I used it...
check these:
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further detail
Sep 18, 2009 | Washing Machines
Maytag Preforma washing machine won't drain water
Good luck !
Sep 12, 2009 | Washing Machines
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
Kenmore Washer Water Leak
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at repairclinic.com
May 22, 2009 | Washing Machines
Small amt of water drips into tub after washer stops fisher payke
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
GE WBXR2090B Top Load Washer Logo
299 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
