Question about Toshiba Satellite P105-S6207 Laptop
I have a Toshiba Satellite 12" TFT Laptop running Windows 2000. A white line has suddenly appeared across the screen. I can not get rid of this annoyance. Can you please help. Granville
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
If you hav enot changed any software on the pc (like the drivers or new video software) the video controller may be bad an need replacement. If you are not familiar with doing it, try a repair shop, it may be more close to the cost of / or more expensive than replacing the laptop.
Posted on Jul 20, 2009
  • Jeannette Sep 04, 2013
    This is a brand new laptop.Only had it fer about 7 months,and this slide out ad just started.And I don't understand why it's there.
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
My laptop screen have lines running across and down i cannot see around them.
Please restart your laptop. As it is just rebooting check to see if the lines are appearing in the boot also. Or if it is only occurring while you are in windows. If it is in both places it is a hardware failure and you need to contact the manufacturer. If it is only in windows then please reinstall the video driver. You can get that from the Toshiba website. -Ravi Shanghavi
Aug 18, 2010 | Toshiba Satellite A135-S4527 Notebook
I have 3 colored vertical thin lines running vertical on my desk top screen, how do I get rid of them? thank you
Does it do this if you attach an external screen and view windows through the external screen. If not, then you have a fault with the TFT panel on the laptop. This would require a replacement TFT panel.
Oct 15, 2009 | Toshiba Satellite A60 Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
White line across my laptop screen vertical
Do a hard reset to the system take the battery out and unplug the power cable, make sure to unplug the acadapter from the system so there should be no power on the system, after that you have to keep the power botton pressed on the laptop for 50 seconds and then release it. connect the battery only and turn on the laptop and go to the bios screen. if the line is present in the bios too than its a pixcel problem which cannot be repaired if under warranty get the screen replaced in case its on the windows screen then you have to reload the video driver.
May 05, 2009 | Toshiba Satellite A135-S4467 Notebook
White line at bottom of display screen getting bigger.
If it's still under warranty they should be able to fix it for you. This sounds like a hardware problem. If you don't have a warranty you'd have to pay to get it fixed.
Dec 03, 2008 | Computers & Internet
White lines
Did you try lately to go to your display settings and change your screen refresh rate ?
Sep 26, 2008 | Toshiba Satellite P105-S6207 Laptop
SATELLITE A200-28S
A line across the screen, either side to side or up and down, is a dead pixel sensor. The only way to fix this is to replace the screen.
Jul 22, 2008 | Toshiba Computers & Internet
Open Questions:
See all Toshiba Satellite P105-S6207 Laptop Questions
Toshiba Satellite P105-S6207 Laptop Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
